Old 09-15-2017, 04:08 AM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
Question Why AFRs and power change after first dyno run?
A month ago I did a few dyno runs on a stock 2017 BRZ with performance package. Upside is it seems to make all the power as advertised, the downside is it only does it for the first run, and everything that follows is significantly richer and down on power; see attached picture displaying the first run and the run that followed a few seconds later. Does anybody know why this is?
I left out the other dyno runs out but they very closely followed the "rich run."
Mileage: ~3000miles
Fuel: ~93AKI Sunoco Unleaded (91+100)
Weather: 91F 29.5in-Hg 22% Humidity
Engine modifications: STI radiator cap, Redline 0w-20
mkodama is offline   Reply With Quote
Old 09-15-2017, 04:16 AM   #2
It's dumping fuel to cool things on the 2nd pull.
Old 09-15-2017, 08:06 AM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
That's about a 4% difference, which is a normal margin or error for dynos.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-15-2017, 08:42 AM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't get the graph. Do you get more power with an 12.79 AFR and less with 10.66 AFR?
Old 09-15-2017, 08:46 AM   #5
8RZ
The Gunshine State
8RZ's Avatar
Yep, generally, lean = more power. But too lean = kaboom.
Current DD: M235i
Old 09-15-2017, 11:21 AM   #6
steve99
Mileage: ~3000miles
Ok with the 2017 ECU their a lot of extra stuff going on with fueling than the older ecu calibrations.
The old logic you had just closed loop and open loop fueling.
the 2017 you have closed loop, open loop and wide open throttle fuel maps.
Also when in open loop (hard acceleration and full throttle) their are now 3 maps the ecu can choose OL fuel map A or B or the WOT fuel map.
It appears it runs the WOT map at full throttle untill the exhaust/cat temps get to a certian level then it default back to one of the much richer open loop fuel maps.
Hence the first runs were probably using the WOT fuel map at AFR 12.5 then as the exhaust/cat temp threshold cut in it switched to the richer OL fuel maps A or B
This is done likely to preserve the life of the primary cat in header (its supposed to last 10 years or something). Once you go catless header (or you dont care about primary cat lifespan) most tuners will likely equalise these tables for max power all the time and run afr arround 12-12.5 for max power at all times. while keeping safe exhaust gass temps
same deal with the multiple timing maps now available.
Tail pipe AFR sensors generally read on the lean side on car with cats (stock their are two).
The Following 4 Users Say Thank You to steve99 For This Useful Post:
CSG Mike (09-15-2017), lazyluka (09-17-2017), TofuJoe (09-15-2017), tyler_win_photo (09-19-2017)
Old 09-15-2017, 11:32 AM   #7
steve99
http://www.endtuning.com/afr.html
The Following 2 Users Say Thank You to steve99 For This Useful Post:
chaoskaze (09-16-2017), nikitopo (09-15-2017)
Old 09-15-2017, 04:49 PM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I guess this is the main reason why they didn't spec the car with a 215ps output and stayed on 205ps. The +10ps are there, but not always ...
Old 09-16-2017, 02:30 AM   #9
mkodama
86 Challenge
Drives: 2017 BRZ
Thanks for the info on multiple maps for full throttle.
At first I figured it was catalyst protection, but then a search didn't bring anything up about this engine having EGT sensors, so how does it decide when and when not to run the 12.5:1 map?
It would be nice for me if I could have the 12.5:1 ratio all the time because I'm already down on acceleration compared to most other cars and the gas mileage is suspiciously poor at the track.
Old 09-16-2017, 03:18 AM   #10
steve99
ecu uses the front o2 sensor heater circuit to estimate cat temp
basicly measures resistance heater circuit using current through heater as reference.
fuel consumption will always be terrible on track , i use about 30l/100km on E85 on track in a 2013
Old 09-16-2017, 06:28 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
We were questioning for a long time why the new cars are not so strong, even though we had many dynos with a +15whp. Some insisted that the gains are only +5whp and not +15whp and they were saying that the main difference is with the shorter FD. Now it is clear what is hapenning. Most of the gains are related with the tune and the ECU changes the AFRs after some time. This has as a result to lose power. Thanks for the finding.
I guess the only option is to have a custom tune. Gas mileage will also improve a bit.
Old 09-16-2017, 01:14 PM   #12
mkodama
86 Challenge
Drives: 2017 BRZ
All my questions are answered. Thanks Steve99!
That's a lot of E85! I've been getting about 26l/100km 9.1mpg on 91AKI gas in the 2017.
Tales from the Dyno: UEL E85 power Shiv@Openflash Engine, Exhaust, Transmission 20 01-20-2016 08:58 AM
How closely should AFRs be monitored when not WOT? post_break Software Tuning 23 06-10-2014 10:36 PM
Awesome Power run: Jeep climbs out of the dyno GeeTee86 Off-Topic Lounge [WARNING: NO POLITICS] 1 06-16-2013 07:47 PM
HKS Hi Power Spec L Dyno Result Ishii Motors Engine, Exhaust, Transmission 4 08-03-2012 02:20 PM
Has anyone run a dyno for HKS Hi Power Spec-L? wollview Engine, Exhaust, Transmission 14 08-01-2012 12:36 AM
