Old 01-12-2023, 04:33 PM   #1
crowbar_combat
crowbar_combat's Avatar
Drives: 2018 BRZ Premium
Horrific drone on a used MXP Comp RS... potentially damaged?
Hello,
I recently bought a used MXP Comp RS catback, and the low-pitch drone was so bad from 2.5k-4k RPMs that it left me with a feeling of pressure in my ears after driving like it was giving me hearing damage and I had to take it off after a day.
I'm also running a catless JDL UEL header which I suspect makes it worse, but I'm wondering if the muffler or resonator was potentially damaged by the previous owner and it may be abnormally loud as a result.
Is this just how these exhausts are, or is this one likely not working properly? Is there a practical way for me to check the integrity of its internals?
Thank you
crowbar_combat is offline   Reply With Quote
Old 01-12-2023, 05:01 PM   #2
RedReplicant
Drives: None
To be expected with a catless uel and that exhaust
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
DocWalt (01-17-2023)
Old 01-12-2023, 05:06 PM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Don't double up, yo.
Old 01-12-2023, 05:37 PM   #4
crowbar_combat
Got it. Live and learn I suppose.
Old 01-12-2023, 05:37 PM   #5
crowbar_combat
What do you mean?
Old 01-12-2023, 09:57 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Originally Posted by crowbar_combat View Post
What do you mean?
Unrestricted header and unrestricted exhaust from two separate brands? You're asking for trouble. Either buy a system that was tuned all together so it won't be horrible, or just run one or the other. A header with the stock muffler is nice.
Old 01-12-2023, 10:19 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
A resonated front pipe will help with drone but it will still be loud. Being used, the packing in the cans could be toast too.
Old 01-13-2023, 09:07 AM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Comp RS is known to drone on its own. I'd probably just sell and find something else. CSG touring is about all I can recommend that shouldn't drone. Beyond that it's a roll of the dice. I tried a few quiet CB/AB and they droned at lower RPMs.
You'll go down the rabbit hole chasing a fix with the existing setup.
Old 01-13-2023, 10:24 AM   #9
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
I once pieced together a JDL UEL catless header, Nvidia catted front pipe, and an MXP Comp RS. It sounded nasty, but it did drone on the highway more than I liked. I ended up selling it four days later for a $120 loss (let's call it a rental) and later picked up a used MXP SP for $500. The SP is much more livable and I totally recommend it in combination with the JDL UEL header.
gkubed is offline   Reply With Quote
Old 01-13-2023, 03:43 PM   #10
crowbar_combat
Appreciate the replies guys! I'm definitely just going to sell it and look for something a bit more mature, oh well. The SP sounds great.
Old 01-18-2023, 02:09 PM   #11
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Or get Q300
Sent from my SM-N986U using Tapatalk
catback, drone, exhaust, mxp
Ecu swappable? Potentially locked ecu kill3rwill Software Tuning 3 03-02-2016 09:44 PM
More Euro cars in trouble potentially. gt8613 Other Vehicles & General Automotive Discussions 4 10-09-2015 02:23 AM
Leds could potentially blow ECU or BSI on 86? dssence Cosmetic Modification (Interior/Exterior/Lighting) 29 03-22-2014 12:37 AM
Potentially headlight stupid question BentAnat Cosmetic Modification (Interior/Exterior/Lighting) 7 08-21-2013 02:32 AM
GTS Man White Order Potentially up for grabs mikedsilva AUSTRALIA 3 08-31-2012 06:32 AM
