Drives: 2013 FRS
I’ve created an exhaust mess
My son and I are fixing up a 2013 FRS as a first car for him, and I’ve created a bit of an exhaust mess. The car has a TRD 1.0 quad outlet exhaust and I recently added a JDL UEL catted header. It’s loud as a combo but just as annoying it resonates a bunch too.
I don’t really want to nuke the header, as I like the power band change, but the bumper is cut for the quad exhaust, so it’s a bit hard to go to something different without bodywork. Can I add a larger resonator? I don’t think that’s likely going to change volume, but maybe cut down on the drone? Thoughts? |
Wheels for Brains
The problem is the TRD exhaust. The USDM TRD exhaust with barrel muffler is known to be quite loud and raspy when you get headers/remove cats
There are other aftermarket exhausts offered with quad tips. Even if the bumper is cut for quad tips, you can also opt for dual tip exhausts.
Blitz, Fujitsubo, HKS, Greddy, and others offer quad tip versions if you are so inclined. Many more options abound if you are willing to consider dual tip |
| The Following 5 Users Say Thank You to EndlessAzure For This Useful Post: | alphasaur (12-06-2022), DocWalt (12-06-2022), NoHaveMSG (12-05-2022), SpeBud07 (12-05-2022), x808drifter (12-06-2022) |
#3 | |
Drives: 2013 FRS
#4 | |
Rust bucket enthusiast
One of the quietest performance oriented catbacks.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#5 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
It also comes down to what your budget it.
| The Following User Says Thank You to weederr33 For This Useful Post: | SpeBud07 (12-07-2022) |
#6 | |
Drives: JRSC BRZ SOLD
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | SpeBud07 (12-07-2022) |
AutoX-10/10ths every run
You didn't mention what front pipe you had on the car, but ensuring that you at least have the stock catted front pipe typically helps with rasp/noise. An aftermarket catted front pipe may help more than the stock one.
has a funny hat
Drives: 2014 BRZ Limited
You’re fixing up a car for a kid as their first vehicle. Kill as much power as possible. Get custom headers made with 3/4” primaries and three extra catalytic converters. You want to make the car as slow and boring as you can. There are too few of these cars as is, no need to hasten the demise of another one in the hands of a young driver.
#9 | |
If I were you, I'd go to a Helmholtz tube calculator and then add one of those. If done right, it will kill the drone and reduce overall sound some as well. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | SpeBud07 (12-07-2022) |
#10 |
Drives: 17 Asphalt 86
Somebody on the forums mentioned cutting out the OEM TRD resonator and welding in a vibrant ultra quiet helped quite a bit with the typical TRD drone/resonance. I found catless UEL+TRD pretty unbearable. Lasted two weeks before selling the catback.
If you wanted a one and done a CSG touring is going to be quiet, then weld on dual tips of your choice. |
| The Following User Says Thank You to RToyo86 For This Useful Post: | SpeBud07 (12-07-2022) |
#11 |
Drives: X5 35d, D90, CX-5 Turbo
Greddy Supreme SP might be a good option as well. I have no personal experience, but my understanding is that it is only slightly louder than stock as just a Catback, but wakes up nicely with a header and front pipe..
Greddy Supreme SP Catback only.. Greddy Supreme SP with UEL Catted Header and Motive Catted Front pipe.. |
| The Following User Says Thank You to LRNAD90 For This Useful Post: | SpeBud07 (12-07-2022) |
#12 |
Greddy SP droned quite a bit with my gruppe-s header. Also had drone issues with a fujistubo axleback. Catted header may help a little in that department.
| The Following User Says Thank You to RToyo86 For This Useful Post: | norcalpb (12-06-2022) |
#13 | ||
Drives: 2013 FRS
#14 | |
Drives: 2013 FRS
| PSA- Don't race on streets. Could Stance have created this crash? | guybo | Off-Topic Lounge [WARNING: NO POLITICS] | 52 | 11-27-2016 10:24 PM |
| Does snow & ice mess up car paint? | Jfheisenberg | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 02-05-2015 07:37 AM |
| not all USB keys created equally? | 7thgear | Electronics | Audio | NAV | Infotainment | 15 | 06-28-2013 07:33 PM |
| My FR-S is a mess | SocalBurt | Issues | Warranty | Recalls / TSB | 17 | 11-21-2012 03:23 PM |
