Old 12-05-2022, 06:43 PM   #1
SpeBud07
Drives: 2013 FRS
I’ve created an exhaust mess
My son and I are fixing up a 2013 FRS as a first car for him, and I’ve created a bit of an exhaust mess. The car has a TRD 1.0 quad outlet exhaust and I recently added a JDL UEL catted header. It’s loud as a combo but just as annoying it resonates a bunch too.
I don’t really want to nuke the header, as I like the power band change, but the bumper is cut for the quad exhaust, so it’s a bit hard to go to something different without bodywork.
Can I add a larger resonator? I don’t think that’s likely going to change volume, but maybe cut down on the drone?
Thoughts?
SpeBud07 is offline   Reply With Quote
Old 12-05-2022, 07:02 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
The problem is the TRD exhaust. The USDM TRD exhaust with barrel muffler is known to be quite loud and raspy when you get headers/remove cats
There are other aftermarket exhausts offered with quad tips. Even if the bumper is cut for quad tips, you can also opt for dual tip exhausts.
  • The cut-out for quad tips simply enlarges the original dual tip factory bumper clearance. Dual tip exhausts will fit just fine under the bumper (albeit the tips won't fill up all of the exhaust cutout area, leaving some empty space). You don't need any bodywork for dual tip exhausts unless the empty space bothers you.
Blitz, Fujitsubo, HKS, Greddy, and others offer quad tip versions if you are so inclined. Many more options abound if you are willing to consider dual tip
EndlessAzure is offline   Reply With Quote
The Following 5 Users Say Thank You to EndlessAzure For This Useful Post:
alphasaur (12-06-2022), DocWalt (12-06-2022), NoHaveMSG (12-05-2022), SpeBud07 (12-05-2022), x808drifter (12-06-2022)
Old 12-05-2022, 07:17 PM   #3
SpeBud07
Drives: 2013 FRS
Any places to start looking for quiet exhausts? I don’t need him waking up the neighbors.
Old 12-05-2022, 07:27 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
https://www.counterspacegarage.com/p...tition-exhaust
One of the quietest performance oriented catbacks.
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (12-06-2022), Dzmitry (12-06-2022), SpeBud07 (12-07-2022)
Old 12-05-2022, 07:29 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
FTSpeed, Japan Parts, CounterSpace Garage, and Kami Speed are a few to start
It also comes down to what your budget it.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 12-05-2022, 07:38 PM   #6
PulsarBeeerz
Drives: JRSC BRZ SOLD
X2 With a Catless header, 3" Catted front-pipe and CSG exhaust my car is barely louder than stock.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Old 12-05-2022, 07:52 PM   #7
whataboutbob
AutoX-10/10ths every run
You didn't mention what front pipe you had on the car, but ensuring that you at least have the stock catted front pipe typically helps with rasp/noise. An aftermarket catted front pipe may help more than the stock one.
Build thread:Here
Old 12-05-2022, 08:21 PM   #8
pope
has a funny hat
Drives: 2014 BRZ Limited
You’re fixing up a car for a kid as their first vehicle. Kill as much power as possible. Get custom headers made with 3/4” primaries and three extra catalytic converters. You want to make the car as slow and boring as you can. There are too few of these cars as is, no need to hasten the demise of another one in the hands of a young driver.
pope is offline   Reply With Quote
Old 12-06-2022, 06:32 AM   #9
KillerBMotorsport
KillerBMotorsport's Avatar
Trying different exhaust is going down a rabbit hole for sure, because sound is so subjective, and results will vary based on driving style and mods.
If I were you, I'd go to a Helmholtz tube calculator and then add one of those. If done right, it will kill the drone and reduce overall sound some as well.
KillerBMotorsport is offline   Reply With Quote
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Old 12-06-2022, 08:51 AM   #10
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Somebody on the forums mentioned cutting out the OEM TRD resonator and welding in a vibrant ultra quiet helped quite a bit with the typical TRD drone/resonance. I found catless UEL+TRD pretty unbearable. Lasted two weeks before selling the catback.
If you wanted a one and done a CSG touring is going to be quiet, then weld on dual tips of your choice.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 12-06-2022, 11:58 AM   #11
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Greddy Supreme SP might be a good option as well. I have no personal experience, but my understanding is that it is only slightly louder than stock as just a Catback, but wakes up nicely with a header and front pipe..
Greddy Supreme SP Catback only..
Greddy Supreme SP with UEL Catted Header and Motive Catted Front pipe..
LRNAD90 is offline   Reply With Quote
The Following User Says Thank You to LRNAD90 For This Useful Post:
Old 12-06-2022, 01:02 PM   #12
RToyo86
RToyo86's Avatar
Greddy SP droned quite a bit with my gruppe-s header. Also had drone issues with a fujistubo axleback. Catted header may help a little in that department.
norcalpb (12-06-2022)
Old 12-07-2022, 10:52 AM   #13
SpeBud07
Drives: 2013 FRS
I was wondering about that, trying a resonator and seeing what difference that makes. Of course doing that would potentially kill resale of it, but it may be worth the experiment.
Old 12-07-2022, 10:55 AM   #14
SpeBud07
Drives: 2013 FRS
I know you're being tongue in cheek, but it was his grandfather's car who couldn't drive it anymore due to health reasons. Super low miles (22k), but not particularly well cared for, so it's been a fun father-son project.
PSA- Don't race on streets. Could Stance have created this crash? guybo Off-Topic Lounge [WARNING: NO POLITICS] 52 11-27-2016 10:24 PM
Does snow & ice mess up car paint? Jfheisenberg Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 02-05-2015 07:37 AM
not all USB keys created equally? 7thgear Electronics | Audio | NAV | Infotainment 15 06-28-2013 07:33 PM
My FR-S is a mess SocalBurt Issues | Warranty | Recalls / TSB 17 11-21-2012 03:23 PM
