Old 09-27-2022, 04:26 PM   #1
15WhiteFRS
Drives: 15 FRS
Transmission noise in neutral
It goes away when clutch is pushed in or in gear.
Gets louder when revving
55k
15WhiteFRS is offline   Reply With Quote
Old 09-27-2022, 05:27 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Sounds normal to me. When the clutch is engaged and the transmission is in neutral, the input shaft spins and the sound is the gears spinning. As our cars lack sound insulation this is audible. Once you press on the clutch the input shaft stops spinning and the noise goes away.
Jason Cammisa raved about a similar sound in the 911R, again caused by lack of sound insulation (at 7:41) -
Ohio Enthusiast is offline   Reply With Quote
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Tcoat (09-27-2022)
Old 09-27-2022, 08:25 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Normal.
Mine got worse when I added the white line trans bushing insert. Transmission noises.
Transmission rattle in Neutral msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-27-2022 01:38 PM
Frs transmission resistance in neutral Raven_frs303 Engine, Exhaust, Transmission 2 08-22-2021 04:49 PM
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 03:21 PM
Grinding noise in neutral WGMGR Issues | Warranty | Recalls / TSB 28 04-12-2018 02:22 AM
MT, neutral 15-10mph slowing, ratcheting noise bcj Engine, Exhaust, Transmission 7 04-18-2013 12:33 AM
