Old 05-18-2019, 04:54 PM   #1
msaikhan
Drives: frs
Transmission rattle in Neutral
2013 frs
had the clutch replaced while the engine was out, so transmission was not dropped. exedy Oem clutch.
Transmission started rattling sometimes in neutral when coming to stop and the noise goes away if i push on the shifter.
How should i about stopping the rattle.
msaikhan is offline   Reply With Quote
Old 05-18-2019, 06:18 PM   #2
humfrz
Originally Posted by msaikhan View Post
2013 frs
First, I would try to simply screw down the shift knob so that it's tight.
If that wouldn't work, I'd call up my buddy @Ultramaroon for his advice.
Here, I'll ring him up for you.
He will want to know if you have any power modifications, who did the work on the engine and maybe have you tried to tighten the bellhousing bolts and the bolts that hold the transmission to the cross member. -
I hate to heap this on ol Ultramaroon, but it's time for my long Saturday nap - ZZZZZZZZZ
humfrz
Old 05-18-2019, 06:49 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Simple fix. Something not bolted all the way down.
By the sounds of it I bet they ripped open the interior to get to the shifter. Zero reason why, you can get to it way easier from the bottom.
Old 05-18-2019, 08:20 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Did they replace the quill (transmission front cover)? If so, they drained and refilled fluid. Every fluid except the factory fill is a little bit thinner and allows the gearbox to make a little more noise when it's in neutral.
It makes sense that if you push on the gearshift the noise goes away. What about if you push in the clutch?
If that's not it then let's consider other stuff. Do you have the invoice?
Old 05-18-2019, 08:53 PM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
It's gearbox rattle, most likely. My car does it too on occasion. My understanding has always been that it is normal, and just something you hear a lot more in this car due to the lack of NVH stuff.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-19-2019, 12:32 AM   #6
humfrz
Are you sure you don't work at a dealership?? -
humfrz
Old 05-19-2019, 05:39 PM   #7
msaikhan
Drives: frs
They didnt replace the trans fluid. I'm using motul300. They didnt replace anything else other than clutch and throw out bearings. They had the engine out for the recall. So transmission wasn't even dropped. And I never had the rattle before clutch replacement.
Old 05-19-2019, 06:22 PM   #8
Ultramaroon
not playing cards
Freaky. I've heard of times when one of the retaining clips has fallen out after TOB service. If you pull the clutch fork forward and try to twist it back and forth before the pushrod comes back out, does it feel nice and tight? It should not wiggle.
Old 09-27-2019, 11:53 AM   #9
msaikhan
Drives: frs
I believe i have tracked down the rattle. It's the clutch fork and slave cylinder piston, somewhere in that area. I moved the clutch fork side to side from the top of the engine and there is so much play and it makes the rattling noise. I checked friend's car and there is much less play. So, is there a bushing or loose bolt that could be causing the excess play?
Old 09-27-2019, 01:23 PM   #10
msaikhan
Drives: frs
i think my retaining clip has fallen just like you said, i have so much play side to side on the clutch fork.
Old 09-27-2019, 02:12 PM   #11
Ultramaroon
not playing cards
Aha!
I have to replace my TOB this weekend. Just noticed it starting to make noise this morning.
Old 09-27-2019, 07:26 PM   #12
humfrz
Aha!
How many miles do you have on your car now?
humfrz
Old 09-27-2019, 09:09 PM   #13
Ultramaroon
not playing cards
Like 56 or 58. I haven't looked since before Idaho. All bets are off because when I swapped out gearboxes, I used the one I had shipped from Cleveland. It seemed the better of the two. No idea how many miles were on it.
Plus I never expected it to last long because I'm always dancing on it. 60-ish feels about right when compared to other owners' reports.
Old 09-27-2019, 10:50 PM   #14
humfrz
OK, so, at that rate, I have another 5 years before I have to start worrying about it -
humfrz
Transmission Noise in Neutral @ Cold Start Jackal84 Issues | Warranty | Recalls / TSB 57 03-01-2021 03:21 PM
FRS Rattle when clutch engaged in neutral savioita Issues | Warranty | Recalls / TSB 20 11-26-2017 04:00 AM
cluck cluck clutch rattle in neutral to engagement??? Packofcrows Issues | Warranty | Recalls / TSB 32 11-14-2015 11:28 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 06:55 PM
Weird rattle when put into neutral SleekMachine Issues | Warranty | Recalls / TSB 1 10-18-2012 10:25 AM
