Old 09-20-2022, 06:08 AM   #1
yzyysy
Drives: GT86
80w90 oil after service?
Hey all,
just recently took my 2013 86 for servicing and realized they used 80w90 transmission oil instead of the 75w90 which is stated in the owners manual. Have been doing a lot of reading and it seems that 75w90 should be used for this vehicle. Should I be worried about this? Or should I call them and request for them to use the correct oil.
yzyysy is offline   Reply With Quote
Old 09-20-2022, 06:54 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Originally Posted by yzyysy View Post
Hey all,
You're fine. Minimum Spec is GL-3, and genuine Subaru LSD (80W90) oil is rated at GL-5. Will not be an issue.
spcmafia is online now   Reply With Quote
Old 09-20-2022, 07:06 AM   #3
yzyysy
Drives: GT86
Interesting. Not saying I know any better than Toyota mechanics, but isn't 80w90 non synthetic (with synthetic oils offering better performance and longevity.)
I couldnt find much information of 80w90 used in 86/BRZs so I got a bit worried considering the owners manual itself says 75w90 spec viscosity, unless the difference between 75 and 80 is minimal?
Old 09-20-2022, 07:21 AM   #4
spcmafia
spcmafia's Avatar
I couldnt find much information of 80w90 used in 86/BRZs so I got a bit worried considering the owners manual itself says 75w90 spec.
Here is a thread that discusses the use of GL-5 fluids. It may help.
https://www.ft86club.com/forums/show...=127005&page=2
Subaru will provide their GL-5 regardless of year.
The Following User Says Thank You to spcmafia For This Useful Post:
Ultramaroon (09-20-2022)
Old 09-20-2022, 07:33 AM   #5
yzyysy
Drives: GT86
Thanks for that, was a good read
So in terms of the actual viscosity rating (GL rating aside) there isn't anything to worry about?
Old 09-20-2022, 07:42 AM   #6
spcmafia
spcmafia's Avatar
Is not something that will make or break your components, Im sure someone will come and chime in and quote the manual, and others will say how GL-3 is the right one, others how GL-4 is about the same. But if you're really worried about it, you can talk to the technician so he can give you more insight on why they chose that viscosity.
The only thing might be that it will take longer to get up to temp, so if you're in an area that gets really cold, might want to sit on the car a little longer in the mornings before driving.
Old 09-20-2022, 07:51 AM   #7
yzyysy
Drives: GT86
Yeah, will probably give them a call tomorrow to see what the rationale behind it was. Thanks again, youve given me a bit of peace of mind for now
The Following User Says Thank You to yzyysy For This Useful Post:
spcmafia (09-20-2022)
Old 09-20-2022, 03:23 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
If shifting is not too stiff for your taste, leave it. Transmission will run more quietly. It's why the factory used thick old-school fluid. The forum is littered with complaints of noisy transmissions after swapping fluids in search of easier shifts. It's a trade-off.
I personally stay away from the multi-rated gl4/5 stuff.
RToyo86 (09-20-2022), x808drifter (09-21-2022)
90k service lynnmichelle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 07-05-2021 11:58 PM
Best service in So Cal.. Cobaltbloo Southern California 5 04-23-2018 03:50 PM
30k service TimmyC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 11-29-2016 12:08 PM
First service dalli BRZ First-Gen (2012+) — General Topics 21 06-18-2014 06:51 PM
Service Verticalx Off-Topic Lounge [WARNING: NO POLITICS] 0 01-04-2014 02:57 AM
