Drives: 2013 FRS
30k service
I just called my 2 local Toyota dealerships and one of them quoted me 230$ and wait time of 2-3 hours and the other quoted me 380$ and wait time of 6 hours for a 30k service.
Are these average prices for a 30k services? Any clue why one is so much more expensive than the other? |
Mr.Fujitsubo
Drives: 2018 STI
30k mile service is what? Spark Plug change?
I don't know...my Subaru WRX reached 188,000KM (116,000Miles) on the original spark plugs without issue lol
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
Drives: 2013 FRS
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
As best I can tell it's an inspection and fluid change.
There was actually a thread a while back from a member in WA State about a service manager trying to bend him over saying that the plugs were part of the 30k service (they're not). Plugs are every 60k according to Toyota. Subaru's 30k service guideline is: 30,000 miles Inspect automatic transmission fluid Replace brake fluid Inspect disc brake pads and discs, front and rear axle boots and axle shaft joint portions Inspect brake linings and drums Perform inspect brake lines and check operation of parking and service brake system Inspect clutch operation Inspect steering and suspension Perform rotate and inspect tires Recommended Inspection fuel systems, lines and connections Replace a/c filter Inspect drive belt(s) [except camshaft] Inspect engine coolant systems, hoses and connections Replace engine oil Replace engine oil filter Recommended Inspection fuel systems, lines and connections Replace air cleaner element Basically, replace/clean your air filters and change your fluids and make sure nothing is fucked up and broken. That's an afternoon job if you've got a jack stand. I'm doing mine next week and I think it's gonna run me a little less than $200 all told. Cabin Air Filter from RockAuto, clean/oil my air filter, Eneos 0w20, Motul Gear 300, and ATE Super Blue, then just make sure everything runs right and isn't destroyed. |
Mr.Fujitsubo
Drives: 2018 STI
There we go, that sounds about right. 60k, not 30k for spark plugs.
Drives: 2013 Raven FR-S
I took my car in today for 30K, which should include replace Brake Fluid, after a hour or so, dealership called to tell me that the service was done! after quickly looking at the receipt, it came up to be $201.88 after tax.
But Brake fluid was not changed: Break down items as follow: 30K SERVICE:----------118.48 OIL FILTER:---------------7.49 GASKET:-------------------2.66 CABIN FILER:------------38.87 5QTS 0W20:--------------22.45 Shop Disposal:-----------10.66 Please tell me I did not get screwed by dealership! I usually perform my own oil change every 2.5K miles, the only reason i took in for service is to keep the car covered under warranty! and I was expecting to have the brake fluid changed. I'll probably need to head back and have a chat with their service director... any other input or suggestions? thanks |
#7 | |
Drives: on the highway to hell
But I would have to say you got screwed on the cabin filter. $38.87 is a rip off. I bought a carbon cabin filter from amazon for around $14 and just replaced it myself in two minutes. |
Drives: MDX, Camry
30k service is a total hoax. The real items are:
1. Oil change 2. Rotation 3. Engine air filter 4. Cabin AC air filter 5. Brake fluid change For 3 and 4, unless you live in a very dusty place, really no need to worry about it. Just take them out and inspect. Remove any leaves etc by vacuuming them carefully and you are done. One filter can last minimum 60k. For 5, I used to replace it myself on my SUV every 3 years, then 4 years, then 5 years and I can never tell any difference. I had a car for which the first time I changed brake fluid was 14 years later. And I could not tell any difference. So if you drive like a sane driver, 5/6 years is good enough. In short, just treat 30k as a normal oil change and rotation. Leave the heavy lifting to 60k. |
so ... I really wanted to know if the price I paid is include the Brake fluid change or not.. cuz I can't really tell what is in that ""30K SERVICE:----------118.48""
#10 |
Drives: 2013 Scion Frs.
What about brake pads?
The clutch fork thingy I keep hearing about? What ever it is that fails on peoples stock clutches? I'm about to have some extra money and I'm at 34k Miles...figure it's probably about time to get it looked at to make sure everything is ok. |
#11 | |
Feeling like thinking....
Barry |
#12 | |
Brake pads will only need to be changed if worn past a certain level. They will inspect and recommend if they need to be changed. No need to change just for the sake of changing.
#13 | |
#14 | |
I recently had to have the flux capacitor on my computer cleaned. Cost me $200 but the guy that did it remotely over the internet was really nice and promised that he would delete the picture of my credit card as soon as he was done with it.
| WORKS BRZ/FR-S Service - Watch For Specials! | WORKS | Northern California | 115 | 01-13-2017 04:40 PM |
| 45K Service | HachiRo | Southern California | 5 | 05-21-2015 07:46 PM |
| First service | dalli | BRZ First-Gen (2012+) — General Topics | 21 | 06-18-2014 06:51 PM |
| Service | Verticalx | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 01-04-2014 02:57 AM |
| 1st service | brz7400 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 09-16-2012 12:37 AM |
