Old 06-15-2021, 10:45 PM   #1
lynnmichelle
lynnmichelle's Avatar
Drives: '13 FR-S Ultramarine
90k service
Hey! Coming to you all for some opinions before I make a bad/uninformed decision. I just had my 2013 in for an oil change after barely driving it during the pandemic. I am at a little over 92k miles and the dealership suggested the following:
- Fuel service ($189.99)
- long term coolant fluid exchange, no coolant in reservoir ($159.99)
- Transmission fluid exchange ($249.99)
- rear differential service ($149.99)
I can't (and am not interested in) doing any of these services myself. I'm looking to see if I really do need to do need to all of them and if you have recommendations on if I should break them up or just do all at once? I may contact the local Subaru dealership to see if their rates are a bit lower as well.
lynnmichelle is offline   Reply With Quote
The Following User Says Thank You to lynnmichelle For This Useful Post:
humfrz (06-16-2021)
Old 06-16-2021, 09:53 AM   #2
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Swapping out your fluids (transmission, differential, coolant) is a good idea. I'm surprised they didn't include brake fluid in their recommendations; I'd do that, too. Find out what they actually do for the $189.99 "fuel service." If it's just dumping an additive in the fuel tank, skip it. If it includes replacing a fuel filter, then ok.
I tend towards the "do all the maintenance....it's cheap insurance" side of life, but I generally do all my own maintenance so it costs less than 1/3 of the prices you mentioned. You might check with a respected local independent shop for another quote; none of those jobs are anything beyond a good basic mechanic's capabilities.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following 3 Users Say Thank You to MuseChaser For This Useful Post:
humfrz (06-16-2021), lynnmichelle (06-17-2021), soundman98 (06-17-2021)
Old 06-16-2021, 02:31 PM   #3
humfrz
I would suggest that you follow the recommendations in the maintenance guide that came with your car.
If your car is running OK, I'd suggest that you skip the "fuel service".
If your car is a MT, that quoted transmission service is too much.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
lynnmichelle (06-17-2021), Tcoat (06-16-2021), Ultramaroon (06-17-2021)
Old 06-16-2021, 03:36 PM   #4
I have no idea what the rates are in the US but all those prices seem way high. And this is coming from a Canada where we usually pay more for EVERYTHING.
humfrz (06-16-2021), lynnmichelle (06-17-2021), StraightOuttaCanadaEh (06-17-2021), Ultramaroon (06-17-2021)
Old 06-17-2021, 02:38 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Seems a bit steep but I'm not an expert at paying for service.
humfrz (06-20-2021), lynnmichelle (06-17-2021)
Old 06-17-2021, 02:58 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What a rip off. I am not sure what is in the"fuel service", if it is an MT transmission the other 3 can be done at the same time on a car lift in about an hour, if it is an AT transmission maybe another 30 minutes.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
lynnmichelle (06-17-2021), Ultramaroon (06-17-2021)
Old 06-17-2021, 01:28 PM   #7
lynnmichelle
Thank you all! It's AT. I will definitely check what the fuel service includes. I'll also try a few different dealerships (including to Subaru) to see if I can price shop. I just wanted to make sure these were actually necessary.
Old 06-17-2021, 05:17 PM   #8
The fuel service is very common and very necessary with direct injection engines. Since direct injection fires the fuel straight into the combustion chamber cars with those engines will get gummed up valves very quickly. This makes fuel service important.
Our cars have direct and port injection. The port injectors shoot the fuel in above the intake valve which keeps it clean. This makes "fuel system" cleanouts redundant.
Odds are they will make it sound very critical but all they actually do is dump a can of crap in to clean everything out. You could do the same for about $20 if it was needed.
MuseChaser (06-17-2021), soundman98 (06-17-2021), Ultramaroon (06-17-2021)
Old 06-17-2021, 07:24 PM   #9
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Pricey as! So ok AT but $150 for the Diff. 2 bolts and $20 of parts
gen3v8 is offline   Reply With Quote
Old 06-17-2021, 08:11 PM   #10
Ultramaroon
not playing cards
Meh. Fifty bucks just to put it on the lift is reasonable. I'd pay extra for a light touch but I never get a taker. I balk at being charged full time for each task when we know that they are all combined - as @NoHaveMSG mentioned.
gen3v8 (06-17-2021), NoHaveMSG (06-17-2021), soundman98 (06-17-2021)
Old 06-17-2021, 10:16 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
a better question is what maintenance have you performed so far? getting to be a lot of new owners that are buying these cars at those mileages with no history from before they got it.
per this owners manual maintenance schedule from 2013, they should be recommending brake fluid replacement, cabin filter(very easy to do yourself with no tools), oil and oil filter, engine air filter, and a tire rotation.
https://www.ft86club.com/forums/showthread.php?t=98730
at 60k, you should've had brake fluid, spark plugs, and trans fluid, replaced, and at 75k, the fuel filter is called for replacement...
what you should be doing in this case really depends on how closely the maintenance schedule was followed so far. historically, i've bought a number of cars around 90-100k, and will always do plugs, all the fluids(just a change, never a flush), and then inspect the rest of the mechanicals for other future repairs.
definitely don't feel obligated to go to any dealer for service. independent shops are just as qualified to do all of the routine maintenance, and will be much cheaper.
and just note-- these cars use subaru super blue coolant. it should be very dark blue. if you have anyone change it, be sure to check the color when they're done.
The Following 5 Users Say Thank You to soundman98 For This Useful Post:
bcj (06-18-2021), MuseChaser (06-18-2021), NoHaveMSG (06-18-2021), Stonehorsw (06-18-2021), Ultramaroon (06-17-2021)
Old 06-17-2021, 10:55 PM   #12
Ultramaroon
not playing cards
^^^ wow! ^^^ 10/10 for bringing out the good shit. Coolant choice is a common sloppy move. Don't let them fill your reservoir with windshield washer fluid either. There are some sad stories here.
Old 06-17-2021, 11:17 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Flat rate is gonna flat rate
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (06-18-2021)
Old 06-18-2021, 01:08 AM   #14
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I say skip the fuel service thing if all they're gonna do is drop some sort of cleaner in there and act like they're doing you a favor.
My one curiosity is about the "no fluid in reservoir" thing tagged onto that coolant servicing quote. If they're saying there's no visible fluid in your expansion tank, that's easily fixed by going and buying a bottle of premixed coolant from Subaru. I know you said you don't want to do any of this stuff yourself, but you can definitely DIY pouring a little fluid into that plastic tank until the fluid reaches the "full" line on the tank and call it good. That aside, if the coolant has never been changed before now, it's worth getting fresh fluid in that system. Just don't let anyone try to charge you three figures just for pouring $5 worth of coolant into your system.
Trans fluid is definitely worth doing, and since you mentioned trying to get a Subaru dealer's shop to work on it, try that. If you find one willing to work on a Scion and not act like it's a whole different car that they can't touch, I think you're a lot more assured that something like the rather involved job of a proper AT fluid replacement is going to be done correctly vs. a Toyota dealer.
Diff fluid, if it hasn't been changed before, definitely needs to be changed with that much mileage on it. If it's been done before and it's been about 50k miles since it was last done, it's worth doing it again at this point.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
lynnmichelle (06-26-2021), soundman98 (06-18-2021)
Best service in So Cal.. Cobaltbloo Southern California 5 04-23-2018 04:50 PM
Second Service discretion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-01-2015 11:50 AM
First service dalli BRZ First-Gen (2012+) — General Topics 21 06-18-2014 07:51 PM
Service Verticalx Off-Topic Lounge [WARNING: NO POLITICS] 0 01-04-2014 03:57 AM
1st service brz7400 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 09-16-2012 01:37 AM
