Old 01-12-2013, 09:19 PM   #1
Jaknar
Jaknar's Avatar
Drives: 2013 Scion FR-S Argento
P0341
Today my engine turned on a solid CEL, So I went by O'reily's and had them read the code and it was P0341. Then after another short drive and a short break the CEL turned off. This is not the first time it has happened. It happened last weekend under the same conditions, but after multiple short stops, it turned off. I don't get the safe mode with this code, and the engine ran fine. Has any one had this quirk? Please and Thank You
Jaknar is offline   Reply With Quote
Old 01-14-2013, 02:59 PM   #2
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
This is a general code and potential solution to the problem. I just recommend you take it into Toyota/Scion/Subaru, whoever you bought it from and get it looked at.
http://www.obd-codes.com/p0341
Surakusa is offline   Reply With Quote
