Old 06-26-2012, 07:54 AM   #1
Heero
Heero's Avatar
Drives: 2-door
DRL & Headlights
Just curious if anyone has looked into getting the DRL to run at the same time as the Headlights? More for aesthetic purposes then anything
Heero is offline   Reply With Quote
Old 06-26-2012, 08:19 AM   #2
RZ86
RZ86's Avatar
Drives: 2012 Toyota GT 86 Manual
I'm going to be looking into this for the AUS version. We have the fog lights/DRLs down under the indicator, and they turn off once the headlights turn on. So frustrating. This is on the GT model mind you, not the GT-S.
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R
RZ86 is offline   Reply With Quote
Old 06-26-2012, 11:17 AM   #3
drftrdie
drftrdie's Avatar
Drives: Ae86,X2 , Scion FRS
The FRS DRL is the high beam ran at a lower voltage by a relay under the hood pulling the relay means ditching your high beams for us in the states. Im curious to see about maybe swapping pin locations in the fuse/relay box under the hood to disable the drl's. But I am now at work and will have to try it when i return home .
drftrdie is offline   Reply With Quote
Old 06-26-2012, 11:37 AM   #4
I find it interesting you can't turn them off. In my last DD (a Chevy) you could disable them by pressing the interior light shut-off button 5 times quickly. It wasn't documented, I discovered it by accident.
Unfortunately you had to do it every time you started the Astro. It may have had that option because the DRLs came on even when the car was in Park.
Old 06-26-2012, 11:51 PM   #5
Heero
Heero's Avatar
Drives: 2-door
I believe it's just to keep the car the same for the NA market since they are legally required to be on at all times in Canada/some states?
Old 06-27-2012, 12:33 AM   #6
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
Just wondering what bulb drl/high beams fRS require. I know the low beams are h11 but if anyone can Lmk what's the high beams are its be much appreciated thnx in Advance
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
Old 07-04-2012, 11:52 PM   #7
Heero
Heero's Avatar
Drives: 2-door
Bump!
has anyone looked into getting the DRLs to run with the headlights? I'm no electrical expert but I'm wondering if its something as simple as grounding a wire?
Old 07-05-2012, 12:04 AM   #8
OrbitalEllipses
Drives: Attitude
Bump!
Buy the wiring diagram and see for yourself. That'd be nice, but I don't think it'll be THAT easy.
To be clear though, aren't DRLs on ALL the time? DRL is the LED strip above the fogs on the (USDM) BRZ models, whereas the "boomerangs" are parking lights, from what I've read on the forum anyway.
Old 07-05-2012, 11:34 AM   #9
Heero
Heero's Avatar
Drives: 2-door
The DRLs do not run at the same time as the headlights. As soon as the headlights are turned on the DRLs turn off. IMO the car would look nicer with the DRLs on at the same time as the headlights at night.
Old 07-05-2012, 12:19 PM   #10
OrbitalEllipses
Drives: Attitude
In that case it might be as simple as PULLING the signal wire that grounds them out. Might.
Old 07-12-2012, 10:52 AM   #11
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
is the boomerang on at the same time as the headlights?
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline   Reply With Quote
Old 07-20-2012, 03:46 AM   #12
GL4787
Toyota Service Writer
GL4787's Avatar
Drives: Whiteout M/T, 2003 Duramax
there's an option to turn off DRL's on a scan tool, but when we did it i lost high beams. they come on but at DRL brightness which is way less bright.
Whiteout Manual
I'm a service writer at a Toyota/Scion dealership, if I can help at all let me know.
GL4787 is offline   Reply With Quote
Old 07-20-2012, 04:43 PM   #13
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
What is the bulb size?
tripjammer is offline   Reply With Quote
Old 07-20-2012, 05:00 PM   #14
empower-auto
Kouki-Monster
empower-auto's Avatar
There's already a write up on this forum about how to remove the DRL resistor box. Search more people.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The headlights.... Rob_g Scion FR-S / Toyota 86 GT86 General Forum 22 06-24-2012 02:56 AM
Anyone here every pulled headlights apart? DarrenDriven Northwest 16 06-15-2012 05:58 PM
Anyone know how to remove headlights? Memphis Cosmetic Modification (Interior/Exterior/Lighting) 25 06-12-2012 07:31 PM
FR-S w/ BRZ headlights :) Carban FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 06-04-2012 11:19 PM
Headlights too dim Franisco Other Vehicles & General Automotive Discussions 10 05-15-2012 04:11 PM
