Old 11-23-2011, 09:23 PM   #1
Franisco
Franisco's Avatar
Drives: D31a
Headlights too dim
I'm really having trouble seeing with the factory bulbs, so I'm looking at getting new ones. I was wondering if anyone has done this..What brands do you suggest? Did a whiter bulb actually help? I'm trying to steer clear of a blue tint
Thanks in advance
Originally Posted by White Comet View Post
No one's buying a Yaris to wind the piss out of it and possibly slam into a mountainside pretending they're the ultimate Tofu delivery person.
Franisco is offline   Reply With Quote
Old 11-23-2011, 10:06 PM   #2
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
I hear good things about HIR type bulbs..
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 11-23-2011, 10:23 PM   #3
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
PIAA lights are awesome
KaliKev is offline   Reply With Quote
Old 11-23-2011, 10:25 PM   #4
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Different color temperature won't make any difference (blue, "super white", 55w=85w, etc), and any kind of coating will only reduce light output. There are high efficiency bulbs which do put out a bit more light, or a better option is a bulb conversion (9004 to 9007 for instance). But depending on how old and worn out those stock bulbs are, just about anything might be an improvement.
A couple of other things to keep in mind: If your headlight lenses are hazy, this isn't helping you. And chances are, the stock wiring to your headlights is causing your bulbs to run at less power than they are rated for. Running 10ga or 12ga power and ground wires out to the headlights, and using the stock harness to trigger a relay will give decent improvements.
For more knowledge, dig through this site:
http://www.danielsternlighting.com/tech/tech.html
old greg is offline   Reply With Quote
Old 11-23-2011, 10:26 PM   #5
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
I'd make sure it's not a clouded housing first, that cuts light output considerably. I replaced mine with Silverstars when one burned out, but couldn't really tell a difference.
Neutral_Eyes is offline   Reply With Quote
Old 11-24-2011, 12:39 AM   #6
Franisco
Franisco's Avatar
Drives: D31a
Thanks for all the help. I'll probably poke around and see what I can do
Old 11-24-2011, 08:47 PM   #7
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
These are what I run in my car. They can be a little pricey, but worth every penny.
The regular Silverstar work fine, but they're slightly on the yellow side.
The Silverstar Ultra Gold package give you a cleaner white light. Plus the brightness level is a bigger jump then what the picture below makes it seem.
The regular SilverStar's are more like the XtraVision ime.
jimmillion is offline   Reply With Quote
Old 05-15-2012, 12:05 AM   #8
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
first of all the stock frs projector is not as good.
but HIDs will be the best option for plug and play setup
if you want better lights, you need to retrofit better projectors
86_ZN6 is offline   Reply With Quote
Old 05-15-2012, 05:10 AM   #9
MRZ415
Drives: 2015 Subaru WRX
I have halogens in my current car, and its bright enough
because I added Osram Rally H7 (which use H9 burner) so
more light.
MRZ415 is offline   Reply With Quote
Old 05-15-2012, 08:09 AM   #10
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
I put the standard Silverlights in my Tiburon, it was a hassle but well worth it, huge difference in brightness and colour temp.
Sport-Tech is offline   Reply With Quote
Old 05-15-2012, 04:11 PM   #11
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
The best bulbs out there right now are the Osram Night Breaker, Philips X-treme Power, GE Nighthawk Platinum, or PIAA Night-Tech. Or if you want to modify some Toshiba HIR bulbs to fit, that would probably be the best choice.
I have tried the Philips X-treme Powers and I currently have the Osram Night Breaker Plus. I like the Night Breakers a little more as they seem a little brighter and whiter. They only seem slightly blue at the edges when you look out the side window to turn. Also make sure your headlamp is very clean. You can buy cleaning kits for them.
Anyway, my night vision is getting worse and nothing compares to a good set of HIDs. That's why I really want the HIDs in the Scion FR-S. I'm tired of ****ing around with halogens. :P
Toyota + Subaru =
Bristecom is offline   Reply With Quote
When will we see LED's in automotive headlights? RRnold Other Vehicles & General Automotive Discussions 44 11-22-2011 06:17 PM
Fugly Headlights Chokonen888 Scion FR-S / Toyota 86 GT86 General Forum 41 10-18-2011 01:51 PM
What's up with Japanese cars and headlights? CyberFormula Other Vehicles & General Automotive Discussions 22 04-14-2011 12:20 AM
A question regarding xenon headlights Go Mango Scion FR-S / Toyota 86 GT86 General Forum 15 04-14-2010 09:14 PM
