Old 07-22-2022, 07:22 AM   #1
Monroetwin
Drives: 2022 GR 86 Premium
Bedding Brake Pads
Quick novice question…
Just had Ferodo DS2500 pads installed (with new fluid too). I need to bed the brake pads without access to a track. My plan is to try to do it in the parking lot at my work tomorrow. Question… Is there any issue using the brakes (lightly) driving around town between now and then? My work is about 15 miles from my house and there are several stop lights. My only other option would be to get up early and find an empty road (rural’ish) and hope to not get interrupted during the process…
Thanks in advance!
Monroetwin is offline   Reply With Quote
Old 07-22-2022, 10:58 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Honestly I haven't had issues just bedding pads driving normally on the street and 1st session of the day at the track. I haven't tried any "bedding" procedures on the street for probably 15 years now! That's using a variety of pads from Carbotech, Winmax, Project Mu, and CSG, and swapping back/forth with various OEM and aftermarket "street" pads. No experience with Ferodo DS2500 though...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
JD001 (07-24-2022), Monroetwin (07-23-2022), norcalpb (07-23-2022)
Old 07-22-2022, 11:21 AM   #3
Code Monkey
Drives: Subaru BRZ
No problem driving around for a while before bedding them properly.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 07-22-2022, 05:33 PM   #4
DrinkenBRZ
Drives: 10 RX-8 Spt, 20 BRZ Ltd, 21 Rubicon
As these guys have said just drive to bed those pads. I only intentionally bed full, hard core compounds now.
DrinkenBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to DrinkenBRZ For This Useful Post:
Monroetwin (07-23-2022), NoHaveMSG (07-23-2022), soundman98 (07-23-2022)
Old 07-23-2022, 06:26 AM   #5
Monroetwin
Ok. Good to know! Thanks for the responses!
Old 07-23-2022, 03:43 PM   #6
norcalpb
norcalpb's Avatar
I knew you had tracked without bedding before so on my most recent track day I decided not to bed my new pads. They smelled awful on my first session, but after that they worked just as well as my last set of bedded pads (DTC-60 pads, probably helped that my old rotors still had bedding from my old DTC-60s)
Old 07-23-2022, 07:01 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Bedding is good if you smear pad on the rotors. Otherwise,... Your Meh May Vary
Old 07-25-2022, 08:43 AM   #8
Autoxer62
I have generally bedded pads (autocross compounds mostly) with 10 hard applications from 40 to 15 on a light traffic street, then park the car overnight. Braking gets notably better at the end of the cycle.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 07-25-2022, 12:45 PM   #9
DS2500? Just drive them normally, and they'll bed over time. No special procedure needed.
Monroetwin (07-28-2022)
Old 07-26-2022, 01:07 PM   #10
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
It's not a problem to drive them around a bit before bedding. You won't hurt anything. If you don't get them bedded before you get to the track, just take the first few laps easy and progressively go harder. Let them cool a lap, then you should be good. The DS2500 is extremely easy to bed-in.
Also, please watch our videos on this topic. If you understand everything in these videos, you'll know everything you need to know on the topic:
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
Bedding Carbotech Pads larryt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-13-2022 09:34 PM
Brake bedding vs. Subaru's break-in, and dust OfficeWorker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 03-07-2018 06:12 PM
Newb Brake bed-in (bedding?) question BigFatFlip Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-16-2016 03:40 AM
bedding in brake pads in GTA area FLYFISHR CANADA 13 06-04-2016 10:42 AM
Squealing Tolerance Exceeded! Re-bedding Pads? ShoShin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 03-13-2014 02:37 PM
