Old 03-06-2018, 05:52 PM   #1
OfficeWorker
Drives: 2018 WRX STI
Brake bedding vs. Subaru's break-in, and dust
I just hit 1,000 miles, following the Subaru-recommended procedures. I have noticed that the OEM pads on the Brembo calipers (2017 PP) seem to produce a good bit of visible dust with more spirited driving (I am guessing these are semi-metallic pads?)
On a previous car I ran the Carbotech Bobcat 1521, which IIRC uses a ceramic compound. They produced very, very little dust, and the dust they produced was not very visible (which isn't a fully fair comparison given the wheels were different colors). Upon installing them, I had the rotors resurfaced. Shortly after installing them, I performed the bedding procedure. After doing this, they seemed to become quieter, more effective, and produced minimal dust.
The Subaru break-in seems to run somewhat counter to most bedding procedures I have read about. My questions are, A) at the 1,000-mile mark, the brake dust is still substantial compared to the ceramic pads I had before - will it reduce at all with further usage?, and B) should these brakes be/should have been formally bedded?
Forgive me if this has already been asked - most of what I found searching for bedding comes back regarding track-use/track pads, which does not apply to my situation!
Thanks
OfficeWorker is offline   Reply With Quote
Old 03-06-2018, 06:44 PM   #2
spike021
spike021's Avatar
Thanks
I can tell you that after about 360 days from pickup of my car, plus roughly 9300 miles I still get tons of brake dust. I think it's just the nature of the PP brakes, honestly.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
OfficeWorker (03-07-2018)
Old 03-06-2018, 07:48 PM   #3
nocoolname
Dusting is usually more of the brand and type of pad than it is to the break-in of said pads.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 03-06-2018, 09:57 PM   #4
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Dust from the 2017 OEM Brembo pads is mild compared to moderately capable track pads. I put some DS2500 pads on...squuuueeeaaakkkk...my wheels are bronze instead of silver...LOL
TofuJoe is offline   Reply With Quote
The Following 2 Users Say Thank You to TofuJoe For This Useful Post:
OfficeWorker (03-07-2018), spike021 (03-07-2018)
Old 03-07-2018, 01:20 PM   #5
spike021
spike021's Avatar
Lol I have this issue with the PP pads actually.
I hadn't cleaned mine in a while and thought they looked disgusting, so I cleaned them even more thoroughly last time and it made me remember how nice the original, clean color looks
Old 03-07-2018, 01:27 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I run the DS2500 on stock calipers with no squeak. Lots of dust.
Old 03-07-2018, 06:12 PM   #7
OfficeWorker
Bummer! I think I am going to opt for a set of 1521 Bobcats then.
Break Dust Prevention? TechnoMaster4 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 06-30-2017 03:13 AM
Best place for brake pad bedding in South SF Bay Area? hpde_addict Northern California 8 01-04-2017 08:48 PM
Newb Brake bed-in (bedding?) question BigFatFlip Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-16-2016 03:40 AM
bedding in brake pads in GTA area FLYFISHR CANADA 13 06-04-2016 10:42 AM
Brake dust or rail dust? Dealership bs? Muskokan Issues | Warranty | Recalls / TSB 12 12-21-2013 09:30 AM
