Old 05-20-2022, 05:14 PM   #1
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Stumped: Oil pressure switch port
This one has me a bit confused. I'm trying to re-purpose the oil pressure port on the engine to add an aftermarket sensor by using a splitter-T. For whatever reason the fitting will not screw into the engine. I have purchased two separate fittings and neither fits. But both of the sensors (the OEM and aftermarket) fit in the engine port and into the splitters. I can even fit the splitters into one another, but in the end neither will screw into the engine by more than half turn. I don't want to strip the threads so I'm hesitant on adding significant force.
Anybody got any ideas?
TheBoss77 is offline   Reply With Quote
Old 05-20-2022, 05:17 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is that adaptor pipe thread, or BPST thread?
Old 05-20-2022, 05:23 PM   #3
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Both of them are 1/8 NPT
Old 05-20-2022, 05:30 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stock threads are 1/8 BPST.
https://www.ft86club.com/forums/showthread.php?t=89666
The Following User Says Thank You to NoHaveMSG For This Useful Post:
TheBoss77 (05-20-2022)
Old 05-20-2022, 05:33 PM   #5
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Gotcha! Thank you. I'll see if I can find a BPST to NPT splitter.
Old 05-20-2022, 05:37 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I ran into this before too so I know the headache. There are some sandwich plates that have ports in 1/8 npt so you don't need an adaptor. I have been running a BPST to NPT adaptor for a long time with no issues though. Just be careful as sometimes the pressure senders have a long probe and it isn't compatible with an adaptor. Or maybe that was the temp sensor, I don't remember
Old 05-20-2022, 05:58 PM   #7
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
I'm just glad that there's a reasonable explanation for the issue and it's not me going crazy or senile. The temp sensor is the one with the longer probe, the pressure sensors are short, definitely no fitment issues there.
Old 05-20-2022, 06:01 PM   #8
FrickingReallySlow
Drives: 2015 FR-S
https://www.amazon.com/gp/product/B0...9ROA0I31&psc=1
Just use this adapter, on the end you put the original oil dummy light, on the sides you put your oil pressure sensor
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Old 05-20-2022, 06:04 PM   #9
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Thanks, but I ended up buying an adapter with BSPT male, BSPT female and NPT female. That way the stock pressure sensor will fit correctly. It's coming from China so it's going to be a while.
EDIT: Disregard the above, realized that this thing also has BSPT female.
Old 05-20-2022, 07:02 PM   #10
fminicooper
Drives: FRS Hot Lava
There is an oil port on top of the engine, closed by a 10mm Hex if I am not wrong.
Looks like safer than havinf an string of connector/splitter.
At least is what I did.
fminicooper is offline   Reply With Quote
The Following User Says Thank You to fminicooper For This Useful Post:
Jdmjunkie (05-20-2022)
Old 05-20-2022, 07:05 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I run my temp sensor there. I just sent it to another member through text.
https://www.rallysportdirect.com/par...waApocEALw_wcB
Old 05-20-2022, 07:31 PM   #12
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Thanks, but I'm already running oil temp sensor in the galley. Can't use the Tee there because the oil temp readings are way off from what OBD is reporting.
Old 05-21-2022, 12:49 PM   #13
Grady
Grady's Avatar
Be careful adding a lot of adapters and weight on an oil pressure line. You should use steel fittings. Long adapters and brass can crack due to vibration.
The Following 2 Users Say Thank You to Grady For This Useful Post:
DarkPira7e (05-21-2022), fminicooper (05-22-2022)
Old 05-21-2022, 06:07 PM   #14
7 skulls
Drives: 2014 scion frs
I ran my oil pressure sensor on a whip from the top oil gallery and used a pivot dual gauge reporting from the OBD for oil temp.
7 skulls is offline   Reply With Quote
The Following 2 Users Say Thank You to 7 skulls For This Useful Post:
fminicooper (05-22-2022), TheBoss77 (05-21-2022)
Searching For a replacement USB port for the factory port for aftermarket radio Kutanks Electronics | Audio | NAV | Infotainment 20 08-21-2021 08:12 PM
Factory oil pressure switch Cubix Engine, Exhaust, Transmission 7 08-17-2019 11:36 PM
Switch to 5w30 has made my pressure gauge crazy BDotG Engine, Exhaust, Transmission 20 05-05-2016 11:52 AM
Eliminate oil pressure switch? @Art_Mighty Engine, Exhaust, Transmission 13 09-17-2015 09:23 PM
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 07:06 PM
