Old 07-28-2020, 02:13 PM   #1
Kutanks
Drives: 2013 Firestorm 6MT,2005 Saabaru 5MT
Searching For a replacement USB port for the factory port for aftermarket radio
Hi Guys (and Girls). I've tried searching but i can't find the answer. I have an Aftermarket CarPlay unit that i'm installing now.
It has the USB port on the back. I want to replace the factory usb port with one that directly plugs into the headunit.
I've seen the adaptor to retain the factory USB port but i never use that one because it charges my phone so slowly
My car is a 2013 and came with the base pioneer radio
Kutanks is offline   Reply With Quote
Old 07-28-2020, 03:05 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
What makes you think the USB port on the radio will charge it any faster? Have you tried it yet? Before you change much
Old 07-28-2020, 03:50 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
This might be close to what you're looking for but I'm not sure it will change how anything performs:
https://www.amazon.com/dp/B00VAIEAUM/
LimitedSlip is offline   Reply With Quote
Old 07-28-2020, 03:56 PM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I installed that port in the center console where the 12V plug used to be, it’s perfect.
Old 07-28-2020, 09:35 PM   #5
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Why can't you use the USB adapter? The power for the USB port is supplied by the head unit, so it shouldn't matter if you run a new cable or use the factory stuff, the amperage would be the same.
People need to remember, these ports are made for data transfer, not for charging, and the amperage reflects that. Typically they put out 1/4 of the power of your wall charger in these situations. But again, that's all dictated by the head unit driving it. Some aftermarkets provide 1A or more, so your new unit might charge it faster. Again that's dependent on the head unit not the wiring. Running new wires won't change your charge speed.
The only reason to run a new USB cable is if you are relocating it or if your factory wiring broke. If neither of those are the case, then just use the adapter.
sharpsicle is offline   Reply With Quote
Old 07-28-2020, 11:22 PM   #6
Yoshoobaroo
TRACKBREAD
Might as well relocate it, the stock port is in a dumb spot for plugging a phone in. You’re bound to have the wire crossing over the shift boot.
Old 07-29-2020, 12:10 AM   #7
sharpsicle
sharpsicle's Avatar
I agree. However the OP said he wants to replace the factory port so his phone will charge faster. I'm illustrating that it doesn't work that way and the cable has nothing to do with charge speed.
Old 07-29-2020, 02:37 AM   #8
geraldjust
Drives: MR2, Sliver BRZ
This depends on your phone. iphone?, android? .. samsung? regular usb A port or does your phone have usb-c?
i might have something.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 07-29-2020, 10:01 AM   #9
LimitedSlip
Maybe figure out which charging standards the head unit and the phone (or other devices) support. Then see if there is a compatible standard between the two. The standard will dictate the kind of cable/connectors you will need.
Below is a chart from 2019 listing the charging standards in existence at that time. (Brings to mind the old adage "It's good to have a nice variety of standards to choose from". Right.)
https://www.digitalcitizen.life/fast-charging-standards
Old 07-29-2020, 06:06 PM   #10
sharpsicle
sharpsicle's Avatar
I guarantee that the USB ports on the back of car radios don't go beyond USB 3.0. I'm confident a majority don't go beyond USB 2.0. So again, the cable really doesn't matter, the perceived 'slow charging' is due to the fact that it's less than 1A being supplied.
Old 07-30-2020, 11:00 AM   #11
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
My Pixel 3XL fast charges from my stock USB port, which is connected to my DDX917WS with an adapter.
This of course will depend on what amperage your new headunit puts out with it's USB port as mentioned a couple of times above.
With the stock head unit it would only slow charge, or actually not charge at all if I was using phone navigation.
wolffbite is offline   Reply With Quote
Old 07-30-2020, 10:26 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
it's important to remember that any 'fast charge' method requires data negotiation between the thing supplying power and the device looking to charge. when that communication doesn't happen, most usb ports charge at the low 'safe' rate.
Old 07-31-2020, 06:09 PM   #13
geraldjust
Im actually working on a device that pops into the stock usb port and connects 12v power and negotiation of higher power. If using standard usb, It has to use the datalines to tell the phone it can charge at a higher rate. Usually this doesn't allow your data to flow through it if you have a head unit that needs it for some reason. The other connection is USB-C that allows the signal to the phone to tell it how fast it can charge but doesn't use the datalines for telling it power. So i guess just depends on if you need data to still flow though it. And what type of port it is.
Old 08-24-2020, 10:56 AM   #14
Kutanks
ok maybe i will just try the adaptor then. im hellla frustrated with this radio compared to my other cars which were all Double-din standard
Radio and USB Port No Power GriffinW Electronics | Audio | NAV | Infotainment 0 11-02-2019 02:56 PM
retain factory aux port rsingh Electronics | Audio | NAV | Infotainment 2 10-23-2015 07:09 PM
Using Factory USB port with Aftermarket HU ruskymx Electronics | Audio | NAV | Infotainment 93 06-10-2015 06:53 PM
Retaining Factory BT Mic w/ Aftermarket Radio ecko04 Electronics | Audio | NAV | Infotainment 4 04-08-2014 06:22 PM
BRZ & USB Port brz007 Electronics | Audio | NAV | Infotainment 14 04-14-2013 08:06 PM
