Old 05-01-2016, 10:51 PM   #1
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Switch to 5w30 has made my pressure gauge crazy
Hi All,
So to set some background -
Innovate MTX oil pressure + temp gauge. Just replaced the pressure sender with a new one about 1.5 months ago. Both temp and pressure read off a beatrush sandwich plate between filter.
Changed to LiquiMoly 5w30 about 4 days ago from Mobil1 0w20.
My oil pressure readings have gone insane, on acceleration I get anywhere from 0-100+ within seconds of each other. Super erratic like.
I thought it was a bad filter that I got so I switched it out with another new mobil1 filter but still being all weird.
The gauge was totally fine before I switched over. Any ideas?
BDotG is offline   Reply With Quote
Old 05-01-2016, 11:25 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Change back to 0w20. No brainer.
Old 05-01-2016, 11:49 PM   #3
Teseo
Drives: frs
And put oem filter
Old 05-02-2016, 01:39 AM   #4
Irace86
Drives: BRZ + Ducati M796
Ummm why? The pressure gauge should measure pressure. Is it oil specific? The sensor itself may not even be vehicle specific--just the adapter. 0-20 or 5-20 is recommended but 5-30 is not crazy. I feel like there is a calibration needed or a bubble is against the sensor or something.
Originally Posted by Teseo View Post
And put oem filter
Again, this shouldnt matter. There are plenty of people and teams running aftermarket filters.
Irace86 is offline   Reply With Quote
Old 05-02-2016, 01:49 AM   #5
Irace86
http://articles.chicagotribune.com/2...e-oil-pressure
Make sure you put enough oil but it sounds like a sending unit issue.
Old 05-02-2016, 07:40 AM   #6
Hagbard
Hagbard's Avatar
Check the wires on the sensor if the one wires tab is lose even a little the wire will bounce on and off the post and will do execatly that had the same problem the other day. Hopefully thats all thats wrong with it for you, I have the exact same setup.
Hagbard is offline   Reply With Quote
The Following User Says Thank You to Hagbard For This Useful Post:
BDotG (05-02-2016)
Old 05-02-2016, 10:33 AM   #7
byun
byun's Avatar
Drives: 2015 BRZ CWP
Move the pressure sender to the galley port. I had originally had my sender in the galley port and then tried the sandwich plate location and the pressure readings were bouncing all over. Went back to the galley port and it stabilized and reads normal again.
Originally Posted by BDotG View Post
Hi All,
byun is offline   Reply With Quote
Old 05-02-2016, 11:00 AM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
My pressure readings are nice and consistent from the galley port. It's where I ran my pressure sensor on my EJ subies too.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
BDotG (05-02-2016)
Old 05-02-2016, 11:16 AM   #9
BDotG
BDotG's Avatar
This is my next course of action, i've always figured that it might not be the best place to read from. The temps are always normal reading from there but seems like a place to get a lot of fluctuation.
Old 05-02-2016, 11:17 AM   #10
BDotG
BDotG's Avatar
Yeah I have to agree, the oil nor the filter should matter. I am using a fairly expensive nice filter that I have run from the beginning with zero issues.
Old 05-02-2016, 11:22 AM   #11
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Just to be clear, you've been running the same part number but you've changed your filter at every flush, right??
Old 05-02-2016, 11:49 AM   #12
BDotG
BDotG's Avatar
Yes lol Fresh filter with every oil change. Not that much of an idiot.
Old 05-02-2016, 11:59 AM   #13
JazzleSAURUS
I've had issues with aftermarket oil filters occasionally, a particular car may not like a particular filter. My Forester XT routinely blows out the media of Purolator fitlers, causing bypass failure, this happened within 500 miles two times, so I switched to S2K/RX8 filters. Problem resolved.
Old 05-02-2016, 12:24 PM   #14
dustmann
Drives: '14 WRB BRZ Limited
I have the same gauge, and I replaced my stock pressure sender with the Innovate sender. I get no fluctuations, my pressure is consistently about 20-30psi higher with 5w30 than it was with the stock 0w20 oil.
I would check to make sure your sensor isn't grounding out somewhere. My old prosport oil pressure gauge did this when the sensor wire got partially melted and was grounding on the engine.
dustmann is offline   Reply With Quote
Made the switch - Subaru 2016 WRX 01s0uljah Other Vehicles & General Automotive Discussions 36 10-20-2015 10:50 PM
Eliminate oil pressure switch? @Art_Mighty Engine, Exhaust, Transmission 13 09-17-2015 09:23 PM
I made the switch... Bobblehead BRZ First-Gen (2012+) — General Topics 13 08-01-2015 10:28 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 12:48 PM
STi to BRZ? Who Else Made The Switch? Haole-Pino BRZ First-Gen (2012+) — General Topics 78 11-01-2013 06:02 PM
