Old 09-16-2015, 06:42 PM   #1
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Eliminate oil pressure switch?
Any opinions on eliminating the oil pressure switch? I have a oil pressure gauge with a zero pressure warning. I want to install an oil temperature sender at the location (both of the accessible galley plugs on the top of the engine are already in use).
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 09-17-2015, 12:31 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
There's a thread in here claiming no issues with just tying off the connector. Personally, I think the oil can icon should be replaced with $$$ because that's all it's good for.
@Art_Mighty (09-17-2015)
Old 09-17-2015, 12:43 AM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I've been running without one for quite a few miles now (and a number of track days), no issues
Just curious, why add a temp sensor in that location when there is already a well placed oil temperature sender that reads just after the pump (basically sump temperature) from the factory. Unless of course you are looking to gather data on the efficiency of different types of oil coolers (pressure switch is post filter and thus post oil cooler) by comparing the pre to post cooler temperatures. If that is the case, you're awesome.
Decay107 is offline   Reply With Quote
The Following 2 Users Say Thank You to Decay107 For This Useful Post:
@Art_Mighty (09-17-2015), Ultramaroon (09-17-2015)
Old 09-17-2015, 03:22 AM   #4
steve99
could you not just put a tee fitting and run the standard oil pressure switch and the aftermarket pressure sensor. from original fitting.
Old 09-17-2015, 03:49 AM   #5
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Correct me if I'm wrong but I've heard some stories on the brass tees possibly breaking off after awhile. I was abit hesitant when deciding between a brass tee and using the galley port.
Brzerker is offline   Reply With Quote
The Following User Says Thank You to Brzerker For This Useful Post:
Old 09-17-2015, 05:55 AM   #6
steve99
if your worried about brass tee fittings then use different material or use the bungs in top of block instead see here
http://www.ft86club.com/forums/showthread.php?t=12191
theier is a bit of an install video here about half way through
[ame]http://www.youtube.com/watch?v=cDfFJ5s6IDg[/ame]
Old 09-17-2015, 07:51 AM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
^This
The fittings come in SS and those are pretty sturdy.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 09-17-2015, 08:40 AM   #8
Brzerker
Brzerker's Avatar
Originally Posted by Sportsguy83 View Post
^This
Ah, SS fittings would be a much better choice of material.
Sportsguy83 (09-17-2015)
Old 09-17-2015, 08:53 AM   #9
celek
Resident Gear Head
celek's Avatar
You are correct Brass T is a horrible solution.
celek is offline   Reply With Quote
Old 09-17-2015, 01:31 PM   #10
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
My Search-Fu is weak :/
Where do you find the mythical SS versions of these adapters and T's? I have looked for them but haven't found any. Recommend search terms?
Old 09-17-2015, 01:34 PM   #11
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Mainly because I have a standalone oil temp gauge and and i I wanted to leave the OBDII port alone for other needs. The fact that it is post cooler is also helpful
Old 09-17-2015, 02:06 PM   #12
Sportsguy83
Drives: Limited BRZ
I bought them from a local shop that specializes in fittings for turbo kits and such, but they have to be somewhere online?
I'll do a bit of search on my end.
Old 09-17-2015, 04:13 PM   #13
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Thank you kindly. If worse comes to worse I'm willing to send the cost plus a reasonable fee for your trouble for you to find and send me stuff (if they're close to you)...
or could you slide me the shops name and I'll call them and ask them for stuff.
I found these and have them comming...
http://www.fastwrx.com/collections/g...ng-adapter-set
...but I would rather have the stainless steel ones
Old 09-17-2015, 09:23 PM   #14
Calum
That Guy
Drives: 2013 asphalt FRS MT
Try parker.com. I've worked with their fittings before, they're good stuff.
The Following User Says Thank You to Calum For This Useful Post:
Least harmful additives to eliminate crickets Muskokan Issues | Warranty | Recalls / TSB 46 05-07-2017 12:10 PM
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 07:06 PM
Best Method to Eliminate Sand ShoShin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-29-2013 04:45 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
Cheapest way to eliminate the torque dip allawd Engine, Exhaust, Transmission 42 04-24-2013 09:40 PM
