Old 05-02-2022, 04:50 PM   #1
saza26
saza26's Avatar
Angry Ball Joint install anguish
So... almost two years have gone by now since I replaced the lower control arms. When I bought my car , had it inspected and was told the lower ball joints needed to be replaced. Had some discussion in another thread here and opted to replace both lower control arms, since that's easier for a diy-er (tho more expensive) than pressing in new ball joints
Haven't had any problems up until now. On a recent drive I noticed at highway speed the car pulling to the left a bit, so I decided must need a new alignment. Upon doing so, the shop tells me the right lower ball joint needs to be replaced. Having replaced the control arms so recently (and feeling a little more confident in my diy skills) I wanted to save some money so I bought the new ball joint on RockAuto and ball joint press kit.
Got everything removed and the old ball joint pressed out with relatively little trouble (we'll ignore breaking two wheel studs ). However when I go to press in the new ball joint, I noticed I can basically press it in with just my hands and light pressure. And if I bump it with moderate force it will fall back out.
I don't know if maybe the control arm was warped in my pressing out the old ball joint? Has anyone run into this before trying to change the ball joints? Do I HAVE to get new control arms? I've heard stories of people tack welding in new ball joints, but that sounds hellla sketchy to me.
Plz help, thx
saza26 is offline   Reply With Quote
Old 05-04-2022, 11:08 PM   #2
JOSEC
Drives: 2014 Subaru BRZ WRB
Personally, when I installed a ball joint a few years ago, I still needed to press in the new one.
Does the old one press in with the same ease as the new one? Cause if that's the case, I would say the get a new lower control arm.
JOSEC is offline   Reply With Quote
Old 05-05-2022, 02:39 PM   #3
saza26
saza26's Avatar
It does yea. I did just order a new lower control arm yesterday. Ugh sux it went out so quick tho. Thats not a known issue is it? Wonder if perhaps something else in the suspension is off and wearing them out faster.
ball joint, control arm, diy, press, suspension
ball joint leak msaikhan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-01-2019 11:17 AM
Tie rod ball joint stuck Killianti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-19-2015 10:32 PM
Need some help, how to disingage the rear UCA ball joint. Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-07-2015 03:52 PM
Ball Joint Replacement, The fun way. FRSPacNW DIY (Do-It-Yourself) Guides 2 06-28-2014 03:04 AM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
