Old 04-30-2019, 04:04 PM   #1
msaikhan
Drives: frs
ball joint leak
2013 frs 125k.
1 in lowered on coils
some negative camber from camber bolts.
The boot is ripped and leaking grease on one side. But no play in the ball joint yet.
Do i have to replace the whole control arm? Does anyone sell just the ball joint?
msaikhan is offline   Reply With Quote
Old 04-30-2019, 04:41 PM   #2
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
I only see complete arms with the ball joint for sale on rockauto, but honestly that's what you want anyway. Have you ever replaced a ball joint? It can be a real pain in the ass, and the tool to do it is at least $150 for a half-ass decent one that won't tear out the threads immediately.
While you're at it, you might go for aftermarket arms that are adjustable, depending on your build goals.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
humfrz (05-01-2019)
Old 04-30-2019, 10:57 PM   #3
j3rf
j3rf's Avatar
I believe Subaru discontinued the ball joint as a part number a while ago. They only sell the whole control arm now.
13 BRZ Limited 6MT Lightning Red
j3rf is offline   Reply With Quote
Old 05-01-2019, 07:52 AM   #4
msaikhan
Drives: frs
i've done one accord before. The plan was to just beat it with hammer. I didn't have plans to upgrade the controls arms, not trying to have crazy cambers, i like the handling with stock arms.
Old 05-01-2019, 08:31 AM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Rockauto has them for $136. OEM replacements. No fancy adjustable parts.
https://www.rockauto.com/en/catalog/...trol+arm,10401
BigTuna is offline   Reply With Quote
Old 05-01-2019, 11:17 AM   #6
maslin
Benz Tech
Drives: 2017 BRZ Premium
125k if it needs a balljoint, it needs caster and camber bushings as well.
Do the whole arm, in and out in 20 minutes
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Tristor (05-01-2019)
LCA Upper Ball Joint Issues (maybe?) NAEightySix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 11-03-2017 12:31 PM
Tie rod ball joint stuck Killianti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 07-19-2015 10:32 PM
Ball Joint Replacement, The fun way. FRSPacNW DIY (Do-It-Yourself) Guides 2 06-28-2014 03:04 AM
Front ball joint dimensions J-W Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-02-2013 05:31 PM
loose ball joint Grip Ronin Issues | Warranty | Recalls / TSB 15 07-09-2013 01:16 PM
