Old 05-02-2022, 03:22 PM   #1
imprezive
Drives: 2017 BRZ - WRB - PP
Uneven brake temperatures (Left to Right)?
First noticed this on the track, but have recreated on the street with heavy, straight-line breaking. The L rotor will be significantly hotter than the R. 700 vs 500 on track use. 210 vs 180 with some straight-line test runs on the street.
Any ideas what the underlying issue may be?
imprezive is offline   Reply With Quote
Old 05-02-2022, 07:52 PM   #2
N234
N234's Avatar
Drives:
Interesting.
I have no answers but a couple ideas.
1. Not enough knock back, check slide pins for slipperiness.
2. EBD is biased and discriminating against the right side
I assume you've already removed braking while turning from your measurement, like down an empty straight line backroad.
Good luck.
Oh could also be that it is time to part out
Sent from my Pixel 6 using Tapatalk
N234 is offline   Reply With Quote
The Following 2 Users Say Thank You to N234 For This Useful Post:
CSG Mike (05-02-2022), mrderp (05-05-2022)
Uneven brake temps and warping after a light track day imprezive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-21-2022 12:21 AM
Front Left (Driver) Brake Lockup B T Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 01-30-2018 03:29 PM
Do I have brake pad left? LudwigMiles Scion FR-S / Toyota 86 GT86 General Forum 9 08-29-2017 08:04 AM
OEM Brake Pads, 50% Life Left Keenercarguy Brakes, Suspension, Chassis 4 02-14-2017 03:11 AM
STOP TECH BRAKE KIT SPECIAL!!!!!!!!! (2 Left) vividracing Brakes, Suspension, Chassis 6 10-15-2014 06:43 PM
