Old 01-23-2018, 03:45 PM   #1
B T
Front Left (Driver) Brake Lockup
Under hard braking in a straight line, my driver's side front brake always locks up long before any others. In fact, I'm not sure I've ever locked up any other wheel at all. I've tried multiple sets of tires, track brake pads, ABS off, and finally moved to a 4 corner big brake package moving bias slightly to the rear, always with the same outcome.
I've had this issue since new under hard braking and have tried to single it down without too much success. All I can think it maybe there's a problem at the central split to each wheel. Has anyone else encountered the same issue?
B T is offline   Reply With Quote
Old 01-23-2018, 06:07 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
If tires (multiple sets, and i guess that pressures were even) & brakes (misc pads & no abs & BBK) & diff (as front) are out of picture, what's left .. alignment?
Old 01-23-2018, 06:18 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
Corner balanced?
Old 01-23-2018, 06:59 PM   #4
strat61caster
strat61caster's Avatar
How do you know it's doing that?
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Cole (01-27-2018), ls1ac (01-26-2018)
Old 01-23-2018, 07:21 PM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Originally Posted by cjd View Post
Corner balanced?
All else being equal I'd go with that.
My miata did the same until I corner balanced the car.
It was way off before that though.
Old 01-25-2018, 01:16 PM   #6
B T
Someone else has suggested corner balance as well, so maybe I'll go that route. It was having the same issue on stock suspension and coilovers.
Different sets of tires have been tested also. Alignment has been done several times due to various circumstances and doesn't seem to have made a difference.
Old 01-25-2018, 03:22 PM   #7
x808drifter
LMGTFY
Did you buy the car new?
Old 01-25-2018, 05:01 PM   #8
B T
had it since new
Old 01-25-2018, 10:11 PM   #9
cjd
cjd's Avatar
Drives: 2017 BRZ
What do you have done suspension-wise? It strikes me as really odd behavior, but I can concoct a possible way if the balance is messed up and the front swaybar is stiff enough relative to everything... I'm still skeptical. It brings me back to the question, how do you know that's the wheel locking up?
Old 01-25-2018, 11:59 PM   #10
ls1ac
ls1ac's Avatar
Hold on, you are able to "lock up" the front tire and get blue smoke with the ABS unit turned on? If so it is not working. Or are you hearing the ABS kicking in? Is it the ABS unit that you are hearing as it applies and releases the brakes to keep from locking up? That sound comes from the unit not the tires, and is located in front of the brake master cylinder.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
Cole (01-27-2018), Icecreamtruk (01-26-2018), Tcoat (01-26-2018)
Old 01-26-2018, 10:32 AM   #11
This ^ makes the most sense.
Old 01-26-2018, 12:41 PM   #12
B T
yeah, it'll smoke the front tire until I back off the brakes. I've felt ABS on plenty of cars in the past as well as on this car back when I first acquired it. I'm pretty sure the ABS isn't functioning correctly. There doesn't seem to be any ABS intervention at the point the tire locks up. I'm taking it in sometime soon to have the module replaced by subaru.
The Following User Says Thank You to B T For This Useful Post:
Tcoat (01-26-2018)
Old 01-26-2018, 01:29 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Wait a sec. In OP there was mentioned among tried out things ABS off. Now it'a about ABS not functioning correctly. Was it switched back at all?
Old 01-26-2018, 02:36 PM   #14
ls1ac
ls1ac's Avatar
OK, first you say it happened when you got the car and now you say you were aware of the ABS working when you got it???
This is interesting as you describe left front locking up first, the steering wheel would pull hard left and the car would try to go left when ever the brakes were used hard. Not a good car to drive.
(In a race car left front first is either a balance/bias issue or the right front caliper is sticking and is slow to engage and will not release as quickly as the left. Pulling first left then right. Should not admit it but have tried to finish a race like this, not fun in traffic.)
The Following User Says Thank You to ls1ac For This Useful Post:
Tcoat (01-26-2018)
abs, bbk, bias, brakes, lockup
Brake rotor temperature right/left and front/rear comparison questions HappyMonkey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 07-07-2017 02:29 PM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
WTB: Driver (Left) headlight FRS/BRZ rayspeed Want-To-Buy Requests 5 03-02-2015 09:39 AM
WTB: OEM Control Arms: Front Left & Back Left norcalpb Want-To-Buy Requests 0 02-26-2015 08:55 PM
