Old 04-17-2022, 12:26 AM   #1
imprezive
Drives: 2017 BRZ - WRB - PP
Uneven brake temps and warping after a light track day
I brought a laser temp gun to a track day for the first time. It was an SCCA "Track Night", so it was only three 20 minute sessions.
The first two sessions my rotor temps were still fairly low (about 250). As I was getting more comfortable for the last session I went a lot more aggressive. There was a large variation from L to R temperature was about 650 on the L and 450 on the R. The track does have more right handers under braking, but that still seems like a pretty large difference between left and right?!
Another strange phenomenon occurred. Prior to the event my rotors were warped. Pretty bad vibration. I had them resurfaced once already and it didn't help for long, so I figured I'd abuse them and replace them after the event. Somehow the vibration almost complete vanished after the event. Did I somehow un-warp them?
Last edited by imprezive; 04-17-2022 at 11:06 PM. Reason: Trying to direct more focus towards the uneven brake temps
imprezive is offline   Reply With Quote
Old 04-17-2022, 12:36 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
makes perfect sense if you didn't pull the ABS fuse or do the pedal dance.
TCS was interceding on your behalf to keep the car oriented.
rotors don't warp.
https://alconkits.com/technical-info...ed-brake-discs
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
Captain Snooze (04-17-2022), churchx (04-17-2022), imprezive (04-17-2022), NoHaveMSG (04-21-2022)
Old 04-17-2022, 12:45 AM   #3
imprezive
I believe I had all traction control turned off. For the 2017+ it's just the long hold button push, right? Pedal dance is for the previous years, IIRC.
I did not disable ABS, but only felt it engage once or twice very briefly.
Learn something new every day. Makes sense now. Thanks!
The Following User Says Thank You to imprezive For This Useful Post:
gen3v8 (04-17-2022)
Old 04-17-2022, 01:31 AM   #4
soundman98
soundman98's Avatar
i believe the only change from '17+ was a less intrusive track mode. i believe press-hold still is the same, where tcs is still active, just the least intrusive mode.
Old 04-17-2022, 05:11 AM   #5
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I run my 2017 long press. No probs very minimal intrusion. No brake overheats unless by ME. May I add I get around my local Track fairly Fast but only in comparison to other drivers. Then again ABS is not my concern, Nannies stopping me from getting on the gas are !.
gen3v8 is offline   Reply With Quote
Old 04-17-2022, 08:30 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
For sure on '17+ the "long hold" completely turns off traction control. Pretty sure it disables everything but ABS. I could not tell any difference between the long hold and the pedal dance on my '17 PP.
https://practicalmotoring.com.au/car...baru-brz-work/
soundman98 (04-17-2022)
Old 04-17-2022, 09:51 AM   #7
soundman98
soundman98's Avatar
some days, i feel like i don't even exist
Old 04-17-2022, 10:02 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ah, but that's were you're wrong!
"Life itself is only a vision, a dream. Nothing exists save empty space - and you! And you are but a thought." - Satan
Old 04-17-2022, 05:22 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I read this post and scratched my head. Huh? I don't understand. I went back and reread your first post in this thread then spotted the link. It was quite well camouflaged and it wasn't surprising I didn't see it on my first read through. Admittedly, I cringed a little when I spotted the link.
My apologies.
Old 04-17-2022, 09:13 PM   #10
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
I notice I've been sitting in traffic too often when I start to get brake judder. "Spirited" driving usually fixes it.
murdoc is offline   Reply With Quote
Old 04-21-2022, 12:21 AM   #11
jflogerzi
jflogerzi's Avatar
Its more of un-even pad deposit on the face of the rotor vs wrapped rotors. And Chances you "bedded" your brakes while on track which got rid of the even pad deposits.
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
CSG Mike (04-26-2022), NoHaveMSG (04-21-2022)
Are these track coolant temps acceptable? TheRealBFKR Tracking / Autocross / HPDE / Drifting 2 05-31-2021 06:06 PM
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
Deciding on a brake pad for light track use rkaywhodat Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 02-01-2017 10:58 PM
Worried about 1st track day oil temps cookiesowns Tracking / Autocross / HPDE / Drifting 74 07-13-2015 12:00 PM
Brake disc warping patterns Strat AFRICA 12 04-02-2015 07:05 AM
