| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: GR86 RC
GR86 Brake Pedal height Adjustment
Free mod to bring brake pedal lower. So that heel toe is more natural and because the gas and brake pedals are more level, the sliding of the right foot between the gas and brake is also more natural and smooth.
Probably same as first gen. Just putting here. 1. Loosen (size 14 spanner) jam nut and remove brake switch. This gives more clearance since you can pull the brake pedal upwards out of the way later when you need to bring the clevis out to turn. 2. Loosen (size 17 spanner) jam nut on brake master cylinder shaft. 3. Remove safety retaining pin and pin. Massange clevis out of the brake pedal. Turn in clevis 2 rounds (you may want to experiment with more) 4. Reverse everything above. 5. Remember to adjust the brake switch such that about 1 to 2mm of blue can be seen. Too little and the brake lights wun come on until the pedal is very depressed. Enjoy heel toeing! |
| Brake Pedal adjustment help | Elliotw | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 06-18-2020 05:50 PM |
| Clutch height adjustment | Hugo | AUSTRALIA | 13 | 04-30-2020 01:12 PM |
| Height Adjustment | Jeremehh | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 01-11-2018 01:40 PM |
| Seat Height Adjustment | Norman Tyler | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 11-30-2014 07:26 AM |
| Clutch pedal height adjustment, just do it | Suberman | CANADA | 0 | 10-24-2013 06:00 PM |
