Old 12-13-2017, 01:48 AM   #1
Jeremehh
Drives: Scion FR-S (Whiteout)
Height Adjustment
I Installed Tein Flex A's a few weeks ago and have been messing with ride height. I'm a little confused on adjusting the rear coilovers. It seems that the Shock Body/Cartridge is lowered to the maximum and is bottomed out on the Mount. At the moment it leaves me with about a 2 finger gap. I want it to be a little lower, around 1-1/2 Finger gap. My question is, do I just leave the shock body/cartridge bottomed out and just adjust the preload?
FYI, These are my first coilovers so I have very little experience/knowledge with them.
Jeremehh is offline   Reply With Quote
Old 12-13-2017, 02:42 AM   #2
Lust
Drives: 2017 Subaru BRZ
Can you take a picture of the rear shock body
Lust is offline   Reply With Quote
Old 12-13-2017, 09:14 AM   #3
dvniemela
dvniemela's Avatar
You can go with rear lower control arms that will lower the car more if the coil is truly maxed out.
Lower Additional 25mm: https://www.86speed.com/products/st-...hoCTi0QAvD_BwE
Lower Additional 25mm to 40mm:
https://store.partsshopmax.com/ZNC6RLCA.html
Lower Additional 60mm: http://www.ft86speedfactory.com/stan...E#.WjE1abbMxBw
dvniemela is offline   Reply With Quote
Old 12-13-2017, 10:20 AM   #4
Jeremehh
The Shock Body is the only thing maxed out, however, there is still 1.4in of threading in between the Height Adjustment Locknut and the 2 Preload Locknuts.
Old 12-13-2017, 12:29 PM   #5
Lust
A picture would be helpful...
Old 12-13-2017, 12:32 PM   #6
strat61caster
strat61caster's Avatar
Yes you will have to "reduce preload" to lower the car to your desired height, go ahead and do it, it's not unusual.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
JazzleSAURUS (01-10-2018), Jeremehh (12-13-2017)
Old 12-20-2017, 02:00 AM   #7
fl4t ftw
Drives: 2013 DGM BRZ, 2016 FiST
I think Tein must have changed something in their manufacturing. I cannot get my Flex Z rear end near the advertised 3” drop. It’s not even flush. I even minimized preload as much as possible. I don’t think that the threads should bottom out in the cup so soon like that. Any other suggestions anyone?
I wish I knew I’d need stance LCA’s before I went and got SPC ones and an alignment.
fl4t ftw is offline   Reply With Quote
Old 12-20-2017, 11:59 AM   #8
strat61caster
are the springs loose under full droop? if not go further on the spring perch
ineedyourdiddly
Old 12-20-2017, 12:01 PM   #9
fl4t ftw
They’re not loose. I just barely made them snug. I still have over a 1 finger gap in the rear with no issues up front.
Old 01-09-2018, 08:31 PM   #10
Daenon
Drives: 2014 Subaru BRZ
Me too
I'm having the same issue with my Tein Flex A's. Fronts will drop until basically rubbing while rears leave a big gap. I assumed I did something improperly during installation until I tested the opposite side rear and it did the same. I guess lowered control arms are the only option? Pretty frustrating since I went pricey and got velox/verus LCA's. Here's a pic of it maxed out if anyone sees anything I'm missing.
Daenon is offline   Reply With Quote
Old 01-09-2018, 10:49 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Try......
http://teinusa-blog.com/applying-suspension-preload/
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
EffaressNOOB (03-27-2018), SuperTom (07-17-2025)
Old 01-09-2018, 11:04 PM   #12
strat61caster
Lower the spring perches, you're not "maxed out"
ineedyourdiddly
Old 01-10-2018, 12:00 AM   #13
Daenon
I'm new to this stuff so I appreciate the help.
The body won't move into the lower housing any more than this. It gets stuck. So when I try to lower the upper perches the body gets jammed and if enough force is given, it will start loosening the preload instead.
This seems more likely what might be wrong... I'm having a hard time imagining the change this would make though. I would set the preload on the perches before re-tightening into control arm, right?
Old 01-10-2018, 04:30 AM   #14
swarb
It was never designed to go super low.
It was designed to have decent amount of travel both in bump and droop, while having a modest amount of lowering adjustment.
Removing preload and lowering the spring perch would get you lower, but you would sacrifice some bump travel.
Passenger seat height adjustment? cbf BRZ First-Gen (2012+) — General Topics 36 09-05-2022 06:32 PM
Clutch height adjustment Hugo AUSTRALIA 13 04-30-2020 01:12 PM
HKS Hipermax IV SP coilovers and height adjustment [YOYO] Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 05-27-2017 02:01 AM
Seat Height Adjustment Norman Tyler Scion FR-S / Toyota 86 GT86 General Forum 10 11-30-2014 07:26 AM
Clutch pedal height adjustment, just do it Suberman CANADA 0 10-24-2013 06:00 PM
