Old 06-13-2020, 12:06 PM   #1
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Post Brake Pedal adjustment help
Hello,
Ive found this post which is a PDF guide to adjusting both the brake pedal and the clutch pedal.
https://www.ft86club.com/forums/showthread.php?t=32194
I'm interested in raising up my brake pedal as under very hard braking its actually under the gas pedal which makes Heel-toe very hard. The PDF states to loose the locking nut and then spin the rod. Well Ive been down there twice and cannot for the life of my loose this locking nut. Hoping some here has done this and can help me.
Thanks.
Elliotw is offline   Reply With Quote
Old 06-13-2020, 01:22 PM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Righty tighty, lefty loosey
Old 06-18-2020, 02:22 PM   #3
Elliotw
Elliotw's Avatar
Took some photos down there. Hoping to get some help still. Anyone done this adjustment before?
Assembly:
Locking Nut:
maybe I should unhook from the pedal?
Old 06-18-2020, 04:32 PM   #4
Ohio Enthusiast
Drives: 2018 BRZ
Looks like you didn't use the right wrench size or didn't grip it properly, what with the nut being partially stripped. It looks like there's some blue loctite there, so you'd need to apply a good deal of force. Also, try heating the bolt/nut with a blower or a small torch to loosen the loctite.
Ohio Enthusiast is offline   Reply With Quote
Old 06-18-2020, 04:55 PM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@Elliotw
If you have this problem, get rid of the Verus Pedal Spacer and get a pedal overlay instead (like the Cusco Sport Accel Pedal).
The Verus spacer moves the accel pedal towards you, which is making it too high
EndlessAzure is offline   Reply With Quote
Old 06-18-2020, 05:50 PM   #6
Elliotw
Elliotw's Avatar
I use to have the pedal spacer but removed in favor of the SRP pedal cover. I am thinking maybe a crowfoot wrench might be good tool to get a good grip and brake() this nut loose. I thought that was just marker but its making sense why this nut is so hard to loosen if there is Locktight on there.
I've also ordered some SS brake-lines & SRP Pedal covers for brake & clutch which I noticed would effectively raise up the foot location.
Gas Pedal Adjustment ML Cosmetic Modification (Interior/Exterior/Lighting) 32 05-01-2017 09:26 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Clutch wear and pedal adjustment mike the snake Engine, Exhaust, Transmission 4 10-29-2014 03:30 AM
Clutch pedal height adjustment, just do it Suberman CANADA 0 10-24-2013 06:00 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
