Old 03-25-2022, 02:31 AM   #1
darkofrs
Drives: 14 frs; drift spec
Key fob transponder motherboard broken
So I recently mounted my air suspension tank onto the roof of my trunk and in doing so I had to drill holes, I accidentally drilled into a board/chip that seems to be mounted on the rear deck and it seems to have something to do with the key transponder. When I try to use my key fob I can't open my trunk or unlock my doors without the physical key.
Anyone know what this exact part is called so I can order it? Or would it be better to get it off a junkyard car.
Also, once I get this new board/chip, do I have to reprogram my key or is it just for like the signal?
edit: i took apart the rear deck and it looks like i drilled into a black box, hopefully this will help identify what part it is
darkofrs is offline   Reply With Quote
Old 03-25-2022, 10:06 AM   #2
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
One of the three-letter government agencies will be contacting you shortly . . .
Could it be the "Door Control Receiver" ?
There are a couple different versions.
Does the connector match H26/27 or H28?
LimitedSlip is offline   Reply With Quote
Old 03-25-2022, 02:56 PM   #3
darkofrs
Yeah that looks to be it, thank you!
Transponder key ECU location help Rx FR-S Electronics | Audio | NAV | Infotainment 4 07-04-2020 03:54 PM
Transponder mounting Pat Tracking / Autocross / HPDE / Drifting 9 03-30-2017 06:06 PM
programming Key to transponder Decimus Southern California 1 03-21-2016 09:54 AM
Mounting location for amb transponder? sstfnv Tracking / Autocross / HPDE / Drifting 7 04-02-2015 02:59 PM
DIY Request: Programming Transponder rba DIY (Do-It-Yourself) Guides 1 05-25-2013 07:53 PM
