Old 03-22-2015, 04:29 PM   #1
sstfnv
sstfnv's Avatar
Mounting location for amb transponder?
I'm trying to figure out the best location for my transponder. Where have you mounted your transponders? Please post pictures.
sstfnv is offline   Reply With Quote
Old 03-23-2015, 06:48 AM   #2
Is it a battery powered or hard wired transponder?
Do you have any body work done?
Old 03-23-2015, 09:05 AM   #3
sstfnv
sstfnv's Avatar
I have the battery powered transponder and the car has no body work done. It is 100% stock except for a forester xt oil cooler.
On my S2000 I had it mounted in front of the radiator but that doesn't work for the FR-S. See the attached picture.
Old 03-23-2015, 09:54 AM   #4
The FRS has a metal panel which may interfere with the signal... I'm thinking on the rear impact beam?
Old 03-26-2015, 08:19 AM   #5
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
For W2W racing you'll want it as far forward as you can without being in an impact area where it'll get ripped off (as timing & scoring measures who crosses the finish line by transponder, not visually watching cars cross the finish line).
But for TT, just in a location where you can get a good read from the receiver.
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 03-26-2015, 09:10 AM   #6
ja1217
Drives: 2004 Toyota RAV-4 5M
I actually have mine mounted to one of the tow hooks underneath the front of the car. I have yet to have any issues with it coming off despite hitting the curbs hard and even a few offs.
ja1217 is offline   Reply With Quote
Old 03-29-2015, 04:26 PM   #7
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Mine is ziptied to the front of the grill.
-mike
AZP Installs is offline   Reply With Quote
Old 04-02-2015, 02:59 PM   #8
hirollaz
Drives: 2013 Scion FRS 10 Series
I have my transponder cradle mounted on my front grille lower driver side corner and haven't had any issues.
hirollaz is offline   Reply With Quote
ECU box location?? RehabJeff86 Electronics | Audio | NAV | Infotainment 2 09-18-2013 02:34 PM
DIY Request: Programming Transponder rba DIY (Do-It-Yourself) Guides 1 05-25-2013 07:53 PM
GEX-P920XM...Receiver mounting location... eXtreme Burrito! Electronics | Audio | NAV | Infotainment 1 11-29-2012 11:03 PM
new badge location... Leonardo Cosmetic Modification (Interior/Exterior/Lighting) 11 08-29-2012 11:06 PM
Fuse Location Shadow215 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-21-2012 08:07 PM
