Drives: 14 frs; drift spec
Key fob transponder motherboard broken
So I recently mounted my air suspension tank onto the roof of my trunk and in doing so I had to drill holes, I accidentally drilled into a board/chip that seems to be mounted on the rear deck and it seems to have something to do with the key transponder. When I try to use my key fob I can't open my trunk or unlock my doors without the physical key.
Anyone know what this exact part is called so I can order it? Or would it be better to get it off a junkyard car. Also, once I get this new board/chip, do I have to reprogram my key or is it just for like the signal? edit: i took apart the rear deck and it looks like i drilled into a black box, hopefully this will help identify what part it is Last edited by darkofrs; 03-25-2022 at 03:21 AM. |
#2 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
One of the three-letter government agencies will be contacting you shortly . . .
![]() Could it be the "Door Control Receiver" ? There are a couple different versions. Does the connector match H26/27 or H28? Last edited by LimitedSlip; 03-25-2022 at 10:31 AM. |
#3 |
Yeah that looks to be it, thank you!
| Transponder key ECU location help | Rx FR-S | Electronics | Audio | NAV | Infotainment | 4 | 07-04-2020 03:54 PM |
| Transponder mounting | Pat | Tracking / Autocross / HPDE / Drifting | 9 | 03-30-2017 06:06 PM |
| programming Key to transponder | Decimus | Southern California | 1 | 03-21-2016 09:54 AM |
| Mounting location for amb transponder? | sstfnv | Tracking / Autocross / HPDE / Drifting | 7 | 04-02-2015 02:59 PM |
| DIY Request: Programming Transponder | rba | DIY (Do-It-Yourself) Guides | 1 | 05-25-2013 07:53 PM |
