Drives: car
How do I change the front sway bar bushings?
To start, really surprised there aren't any tutorial threads about this 10 years into the car's life. I think I've run into more difficulty on this than I expected - I thought this would be a quick 10 minute job but..
I have taken the wheels off and removed the plastic cover near the front sway bar, and notice that I don't have any room to undo the bolts on the sway bar bushings. How do I change out the front sway bar bushings? Do I have to undo the entire sway bar from the subframe as if I were following a tutorial install for an aftermarket sway bar? Last edited by radroach; 03-23-2022 at 03:14 PM. |
TRACKBREAD
It’s really easy, you just remove the bracket that holds the sway bar bracket on. It’s 2x2 bolts per side.
| The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post: |
Drives: 2018 BRZ
I replaced the bushings on both sway bars. The rears are a 10 minute job. For the fronts the bar needs to come out of the car entirely, which is quite the pain with all the panels that need to be removed for that, but otherwise fairly simple.
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | radroach (03-23-2022) |
Drives: 2017 BRZ w/PP
here is a video of how i did it
| It's the Little Things - Sway Bar Bushings | Capt Spaulding | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-28-2021 02:35 PM |
| Trd sway bar bushings? | islandguy69 | Issues | Warranty | Recalls / TSB | 3 | 09-30-2017 01:18 PM |
| TRD Sway Bushings | Sweet | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-26-2017 06:34 AM |
| Is the front sway bar bushings liquid filled? | Rayme | Issues | Warranty | Recalls / TSB | 13 | 10-02-2014 05:06 PM |
| Urethane Sway Bar Bushings? | phm14 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-16-2013 10:32 PM |
