Old 07-20-2017, 07:00 AM   #1
Sweet
Sweet's Avatar
Drives: '15 Scion FR-S
TRD Sway Bushings
I'm sure its been asked before I just can't find the answer....
Has anyone found replacement bushings for the TRD front bar(21mm) that use the OEM saddle???
I can't find a toyota part#
The only option I have come across is SuperPro, though it looks like their bushings are made-on-order and would be 6-8 weeks delivery.
Thanks
Sweet is offline   Reply With Quote
Old 07-21-2017, 12:52 PM   #2
Sweet
Sweet's Avatar
Nothing?
Old 07-21-2017, 08:04 PM   #3
stevesnj
stevesnj's Avatar
What's the bushing saddle diameter?
My 2016 Build thread
Old 07-21-2017, 09:41 PM   #4
H1C
Drives: 2014 FR-S MT
Here's the box that my replacements came in. You can order them here:
http://parts.autonationtoyotasouthau...a/ptr1118130aa
My first set wore out and got squeaky after less than a year using the supplied silicone lubricant. I used Mobil 1 red suspension grease on this second set and they're holding up much better (and quieter).
H1C is offline   Reply With Quote
Old 07-26-2017, 06:34 AM   #5
Sweet
Sweet's Avatar
Excellent thank you
WTB Rear TRD sway bar and bushings. Boostmaniac Want-To-Buy Requests 0 09-05-2016 09:10 PM
FS: OEM 16mm WRX rear sway bar w/Whiteline bushings norcalpb Brakes, Suspension, Chassis 13 01-20-2015 05:10 PM
FS: Stock sway bars with bushings Tim_Asphalt_FRS Brakes, Suspension, Chassis 12 10-09-2014 11:56 AM
Is the front sway bar bushings liquid filled? Rayme Issues | Warranty | Recalls / TSB 13 10-02-2014 05:06 PM
Urethane Sway Bar Bushings? phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-16-2013 10:32 PM
