Old 02-26-2022, 10:06 PM   #1
amelo
Drives: '22 BRZ
Gen 2 LV Transmission Fluid
I plan to do an early transmission fluid change in my 2022 BRZ and noticed that the manual recommends OEM Manual Transmission Gear Oil LV 75W oil or other GL-4 75W oil (as opposed to 75W90 for gen 1).
From digging through old threads, a lot of people had good experiences with slightly thinner oil like Pentosin MTF2 and Redline MTL (or even MT-90) in colder climates, which made me want to give it a try. Based on the 2nd gen manual's recommendation for a low viscosity oil, should I be sticking to something like Redline MT-LV over MTL? Does this mean the factory fill is most likely thinner than MTL? I can't really find much about MT-LV here and was hoping someone might have more experience with it and can compare it to MTL.
amelo is offline   Reply With Quote
Old 02-27-2022, 07:50 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I would just stick with same grading oil
Old 02-27-2022, 07:56 AM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The MT-LV is what you will want.
dragoontwo is offline   Reply With Quote
Old 03-02-2022, 09:21 AM   #4
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Straight 75w is a lot thinner than what was in the old car. Stick with that if its not a track car, It will do what you want.
I was one of the people who put $80 worth of Pentosin MTF2 in my trans at 40k. I wish I could do it again, but they dont make it anymore. Im probably going with the Counter Space garage (CSG) 50/50 mix they have on their site, or Redline MTL when I hit 80k. Not long from now.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 04-15-2022, 07:06 PM   #5
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Checking CSG site and don't see any 50/50 mix combos. I recall back a decade or so the subaru crowd figured out some mix of Motul and something else I forget. But that was not the 86 platform.
I've read good comments on some Ford manual gear oil, but would have to dig the numbers back up. I looked for that Pentosin before I realized it's now obsolete. Darn, sounds like it works well with 1st gen transmissions.
If you know the mix, please share. I'm running Motul300 and it's been worse for me than OEM in my opinion. Makes the car more notchy, but I've also added perrin shift bushing, whiteline trans insert, stage 2 clutch and other stuff. But the change to Motul doesn't seem to help until it gets good and warm. PNW near Portland for reference.
jeepmor is offline   Reply With Quote
Old 04-18-2022, 09:24 AM   #6
Westen86
Purist
Westen86's Avatar
https://www.counterspacegarage.com/p...ght-shockproof
Old 07-07-2022, 08:40 PM   #7
sato
sato's Avatar
Drives: Dodge Patitas
Just noticed this in Redline's Website. Anybody tried it?
I was running a mix of MT90 / Pennzoil Synchromesh with good results. However, my mechanic blew a head gasket and filled transmission completely with Pennzoil Synchromesh when he replaced clutch. Transmission is a noisy mess right now, so I was considering a full fill of MT-LV.
Old 07-07-2022, 09:18 PM   #8
dragoontwo
dragoontwo's Avatar
I have not put in it my gen 2 yet, but will try it. I did put it in my '20 and found it a little better than the stock fluid for street driving.
The Following User Says Thank You to dragoontwo For This Useful Post:
sato (07-09-2022)
Old 07-08-2022, 01:17 AM   #9
DrinkenBRZ
Drives: 10 RX-8 Spt, 20 BRZ Ltd, 21 Rubicon
Pentosin mtf2 has been superseded by ffl4 fwiw.
DrinkenBRZ is offline   Reply With Quote
Old 07-08-2022, 06:25 AM   #10
cueball89
Drives: 15 Impreza
FFL4 returned a DCT fluid, but I did find TITAN SINTOFLUID FE SAE 75W.
https://www.generaloils.net/PI_TITAN-SINTOFLUID-FE-75W_e.pdf
cueball89 is offline   Reply With Quote
Old 07-09-2022, 03:41 AM   #11
DrinkenBRZ
DCT fluids are gl4 and additised for synchronized transmissions. They intended the ffl4 for both types. DCT specific fluids are simply closer to atf in viscosity, like all the other fluids referenced in this thread. Another great option would be Ravenol mtf2 if one wants similar viscosity to the esteemed Pentosin.
Old 07-09-2022, 09:40 AM   #12
cueball89
Drives: 15 Impreza
Interesting information about the DCT and ATF fluids. The FFL4 looks like it's spec'd for GL5.
Some TDS sheets for some of the lower viscosity oils discussed.
https://www.ravenol.de/storage/app/m...1221103_en.pdf
https://www.generaloils.net/PI_TITAN...D-FE-75W_e.pdf
https://s3.amazonaws.com/fcp-pdf-fil...COLOR_Rev2.pdf
https://1c2a8a2161d644d95009-22d26b3...nto_MTF2_2.pdf
https://www.redlineoil.com/Content/f..._INFO_2021.pdf
https://www.redlineoil.com/Content/f..._INFO_2020.pdf
Old 07-11-2022, 02:03 AM   #13
bradsm87
Drives: It has 4 wheels
Considering that all of the synchros except for one are the exact same part number as gen 1, it's safe to say that the extremely thin oil is for a tiny economy improvement at the expense of wear protection and that there are no mechanical changes to make it only suit thinner oil.
I'll be switching to Redline MT-85 75w-85 after the first 15,000km. I don't trust the watery stock fluid for any longer than that.
bradsm87 is offline   Reply With Quote
Old 07-11-2022, 07:27 AM   #14
DrinkenBRZ
Originally Posted by bradsm87 View Post
Considering that all of the synchros except for one are the exact same part number as gen 1, it's safe to say that the extremely thin oil is for a tiny improvement at the expense of wear protection and that there are no mechanical changes to make it only suit thinner oil.
Have they not revised tolerances elsewhere? Thinner may be more appropriate if so.
The Following User Says Thank You to DrinkenBRZ For This Useful Post:
cueball89 (07-11-2022)
Automatic Transmission Fluid, is this what you use? qijian Engine, Exhaust, Transmission 2 11-30-2017 01:41 AM
transmission fluid John27 Scion FR-S / Toyota 86 GT86 General Forum 7 04-25-2017 08:14 PM
Transmission Fluid euthqt Issues | Warranty | Recalls / TSB 8 04-14-2016 08:20 AM
MT Transmission Fluid mstoochn Scion FR-S / Toyota 86 GT86 General Forum 1 06-14-2015 09:06 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
