Old 11-28-2017, 03:42 AM   #1
qijian
Drives: FRS
Automatic Transmission Fluid, is this what you use?
Is this the right automatic transmission fluid to put into our auto transmissions? I also saw the Toyota WS listed when i searched but want to make sure before purchasing.
qijian is offline   Reply With Quote
Old 11-28-2017, 02:16 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The manual calls for WS. Personally I use this and it seems to last longer under hard driving compared to OEM (Toyota WS). If you just DD OEM should be fine.
https://www.redlineoil.com/d6-atf
Old 11-30-2017, 02:41 AM   #3
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Yeah i saw it say to use WS.
Decimus is offline   Reply With Quote
Automatic Transmission Fluid Cooler. ?? connor_lol Engine, Exhaust, Transmission 177 01-02-2023 10:02 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
AUTOMATIC transmission fluid change DIY?? qijian DIY (Do-It-Yourself) Guides 3 08-31-2017 09:34 AM
Changing Automatic Transmission Fluid euthqt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-01-2016 04:16 AM
AUTOMATIC TRANSMISSION FLUID? How many L ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-21-2015 01:43 AM
