Drives: 2017 86
how to disconnect the ignition coil? (pic)
I'm doing a spark plug change on the 2017 Toyota 86 without raising the engine. On the passenger side, the outer (closer to front) ignition coil pulls out easily without having to disconnect the boot from the wire. The problem is with the inner (closer to windshield) ignition coil. There is no room to just pull it out, due to the rubber tube, it has to be disconnected and pulled forward. Attached is the pic of the front coil with the connection. I've never seen this kind of connection, it has this metal wire clip. I don't want to break it. Anyone know how to disconnect it without breaking? Thanks.
Wheels for Brains
push straight down on that metal wire and pull the connector away
Jest pull the fat wire out of the top of it. - ![]() (oh wait, what year is this - )
Drives: Dodge Patitas
#6 | |
Drives: 2013 Rally Blue BRZ
You should really just raise the engine. It's not that big of a deal and really makes the job easier. Sorry I know that's probably not what you want to hear but it's the truth. Don't be intimidated! If you unbolt the engine it's really easy to lift it up a bit with a jack. |
| Ignition coil questions | hpde_addict | Engine, Exhaust, Transmission | 20 | 05-12-2017 10:34 PM |
| CEL P0351 Ignition Coil A | Exrald | Issues | Warranty | Recalls / TSB | 16 | 03-23-2017 11:09 PM |
| Ignition coil information | 1quickchic | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 02-12-2017 09:10 PM |
| Ignition Coil A CEL | Whats that smell? | Issues | Warranty | Recalls / TSB | 12 | 10-10-2016 01:09 PM |
| Coil ignition pack | D86Ellis | Issues | Warranty | Recalls / TSB | 7 | 09-20-2016 02:01 AM |
