Drives: WRB Turbo Brz
I opened bleed nipple with clutch not depressed
Title says it. Please don't make me feel dumb. But yeah, my fluid was low and all I was gonna do was add some clutch fluid and get any extra air out. Ended up with a pedal to the floor with no pressure. The clutch pin is stuck in the released position, no matter the position of the clutch. How do I fix this, and what tools are needed?
Would attaching a manual fluid extractor like this:
https://www.harborfreight.com/23-gal...tor-62643.html to the bleeder nipple and pulling brake fluid to the slave cylinder to build pressure work? |
ProCrastinationConsultant
you've got air in the clutch line. the line needs to be bled to fix it.
this video is the exact same procedure that you can do yourself.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | humfrz (12-24-2021), Ultramaroon (12-23-2021) |
not playing cards
It's ok. The assist spring holds the pedal to the floor if nothing is pushing back. Just close the nipple and make sure there's some fluid in the reservoir before pulling the pedal back up by hand.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
Drives: 2013 frs base
And while he's at it, he should go under the dash and remove that clutch assist sprang. He'll be glad he did, I am.
#6 | |
not playing cards
This is the real deal.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (12-23-2021) |
Fixed it. Ended up just taking it all out and unscrewing myself.
not playing cards
What did you take out?
#10 |
could try one of those vacuum suckers
#11 | |
Professional wrench
Drives: 2020 BRZ ST RS
Of course it wouldn't hurt to properly bleed it, but seeing as you are where you are, maybe get some help? PS, I don't mean to be mean about this, its just factual. You can make it worse if you mess up the bleeding procedure.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
| The Following 2 Users Say Thank You to JohnH For This Useful Post: | Tcoat (01-06-2022), Ultramaroon (01-06-2022) |
| Noise when clutch depressed - Mornings | LarryBA2017 | AFRICA | 12 | 12-07-2017 01:16 PM |
| Clutch Squeaks when depressed - out of warranty | Zerwow | CANADA | 7 | 07-31-2017 04:56 PM |
| Valve/nipple (bleed?) next to clutch line? | BRZyJ | Engine, Exhaust, Transmission | 2 | 06-14-2017 01:28 AM |
| Squeaky Clutch when depressed! | oppiee | Issues | Warranty | Recalls / TSB | 29 | 09-01-2016 08:01 PM |
| Vibration/Noise when clutch is depressed | Ravenlokk | Issues | Warranty | Recalls / TSB | 17 | 12-02-2013 11:15 AM |
