Old 12-22-2021, 08:56 PM   #1
toughguy39
toughguy39's Avatar
Drives: WRB Turbo Brz
I opened bleed nipple with clutch not depressed
Title says it. Please don't make me feel dumb. But yeah, my fluid was low and all I was gonna do was add some clutch fluid and get any extra air out. Ended up with a pedal to the floor with no pressure. The clutch pin is stuck in the released position, no matter the position of the clutch. How do I fix this, and what tools are needed?
toughguy39 is offline   Reply With Quote
Old 12-22-2021, 10:04 PM   #2
toughguy39
toughguy39's Avatar
Would attaching a manual fluid extractor like this:
https://www.harborfreight.com/23-gal...tor-62643.html
to the bleeder nipple and pulling brake fluid to the slave cylinder to build pressure work?
Old 12-22-2021, 10:07 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
you've got air in the clutch line. the line needs to be bled to fix it.
this video is the exact same procedure that you can do yourself.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
humfrz (12-24-2021), Ultramaroon (12-23-2021)
Old 12-22-2021, 10:36 PM   #4
It's ok. The assist spring holds the pedal to the floor if nothing is pushing back. Just close the nipple and make sure there's some fluid in the reservoir before pulling the pedal back up by hand.
bcj (12-23-2021), jcw99 (12-23-2021), soundman98 (12-22-2021)
Old 12-23-2021, 11:25 AM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
And while he's at it, he should go under the dash and remove that clutch assist sprang. He'll be glad he did, I am.
Old 12-23-2021, 01:00 PM   #6
I regret it. I would've reinstalled it long ago but the spring perch accidentally went out with the trash. Sad story. My wife felt terrible.
This is the real deal.
blsfrs (12-23-2021)
Old 12-23-2021, 03:58 PM   #7
toughguy39
toughguy39's Avatar
I tried that and there's just no pressure to pull the fluid out pumping the pedal or even sucking through the tube :/
Old 12-23-2021, 09:33 PM   #8
toughguy39
toughguy39's Avatar
Fixed it. Ended up just taking it all out and unscrewing myself.
Old 12-23-2021, 09:41 PM   #9
What did you take out?
Old 12-23-2021, 10:21 PM   #10
soundman98
soundman98's Avatar
could try one of those vacuum suckers
Old 01-06-2022, 03:18 PM   #11
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
this.
Of course it wouldn't hurt to properly bleed it, but seeing as you are where you are, maybe get some help?
PS, I don't mean to be mean about this, its just factual. You can make it worse if you mess up the bleeding procedure.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following 2 Users Say Thank You to JohnH For This Useful Post:
Tcoat (01-06-2022), Ultramaroon (01-06-2022)
Noise when clutch depressed - Mornings LarryBA2017 AFRICA 12 12-07-2017 01:16 PM
Clutch Squeaks when depressed - out of warranty Zerwow CANADA 7 07-31-2017 04:56 PM
Valve/nipple (bleed?) next to clutch line? BRZyJ Engine, Exhaust, Transmission 2 06-14-2017 01:28 AM
Squeaky Clutch when depressed! oppiee Issues | Warranty | Recalls / TSB 29 09-01-2016 08:01 PM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 11:15 AM
