Old 12-17-2021, 03:18 AM   #1
Brz-123
Squeaky Clutch
Hi All, I have a very squeaky clutch at the minute. The sound comes from under the hood and is not the clutch spring. It happens with the engine off and on , so is not the TOB. Anyone can advise what it could be and how to fix it?
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 12-17-2021, 04:32 AM   #2
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
There's quite a few threads around about this. It's your clutch fork.
You have to remove the clutch slave cylinder (2x 14mm bolts), remove the clutch fork boot, and put some thick grease behind the fork, on the small sphere it pivots on. Also lube the contact point between the slave piston and the fork, while you're at it.
All this can be done from under the hood. Shouldn't take long. Also, be sure to drive the car a bit after the manipulation, the squeak may still be here at first, but warming the car up will help the grease become more fluid and get where it needs to go.
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Brz-123 (12-17-2021)
How to fix squeaky clutch for good cat94 Issues | Warranty | Recalls / TSB 15 09-16-2020 09:27 PM
How I fixed my squeaky clutch jacjac3 Issues | Warranty | Recalls / TSB 40 09-27-2017 11:35 PM
Squeaky Clutch when depressed! oppiee Issues | Warranty | Recalls / TSB 29 09-01-2016 08:01 PM
squeaky clutch issue bhbnuckle Issues | Warranty | Recalls / TSB 3 06-27-2016 04:58 PM
Squeaky clutch V1B Engine, Exhaust, Transmission 24 06-16-2016 04:48 AM
