Drives: 2013 Asphalt FR-S/2003 Honda Accord
squeaky clutch issue
Anyone had Clutch squeaky issue? (mostly throwout bearing issue) which a lot of 86 owner has. It makes sound from last 2 inches when It travel to the bottom.
It this will go away with just some of lub work? This video is after driving about an hour. when car is cold there's no squeaky or crunchy feeling Thanks! Last edited by bhbnuckle; 06-27-2016 at 03:51 PM. |
Oh, my ....... ANOTHER clutch making noise ........
![]() Someone should make a "diagnostic tree" for this aberration. @bhbnuckle ..... in your case, I would suspect: * maybe the return spring could use a shot of lub * maybe a part of the linkage/pedal under the dash needs a lub * maybe the clutch fork is dry humfrz |
Thanks humfrz. and yes again!!
This need to be placed on TSB I was thinking of take peddle spring out too, but afraid of warrany will be voided by doing that. Actually one of my mechanic friend offered peddle spring will solve the issue (I didnt believe him lol) Anyone here removed their spring and squeaky gone? |
Well, if it is the spring, you should be able to douse it with silicone spray and quiet it down. No need to remove it.
OBTW ....... one thread per problem is usually sufficient ...... ![]() humfrz |
| How I fixed my squeaky clutch | jacjac3 | Issues | Warranty | Recalls / TSB | 40 | 09-27-2017 10:35 PM |
| Squeaky Clutch when depressed! | oppiee | Issues | Warranty | Recalls / TSB | 29 | 09-01-2016 07:01 PM |
| Squeaky clutch | V1B | Engine, Exhaust, Transmission | 24 | 06-16-2016 03:48 AM |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| clutch issue | yurgirlishot | Issues | Warranty | Recalls / TSB | 14 | 11-15-2013 04:20 PM |
