| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Oil Filter
Is the oil filter same as Forester? Does anyone have the part number?
Getting ready for the 1k breakin oil change |
Drives: 22 BRZ limited
Go pop your hood and get the number. It's printed right on the side.
Drives: 22 BRZ Limited
Here's the part number. I ordered it from that site but not trying to push them - I just couldn't find anything aftermarket at the time.
https://www.subarupartsdeal.com/part...5208aa170.html |
#4 | |
Drives: 2019 BMW M2C
Does the oil pan plug use a crush washer? I don't see one in the parts blow up.
#6 | |
It does - same as previous gen: https://parts.subaru.com/p/Subaru__/...803916010.html |
The car came without, but on the manual is listed as optional. I installed for piece of mind, used from gen1.
#9 | |
Drives: 2005 Toyota Camry
I had this issue with my 2013 https://www.ft86club.com/forums/showthread.php?t=54142 |
#10 |
Drives: Too fast
Optional is the replacement of it, not its presence.
#11 | |
#12 |
I had to use a dental tool to remove my washer. Which was nearly invisible.
#13 |
Drives: Arriving
I’ve never changed my oil myself but I just hit 1k miles in my brz. So, do I always change the oil filter when I change the oil and also, what oil do you recommend?
#14 |
Drives: ‘22 CWP
The little washer gets painted over at the factory so it sticks to the drain plug. Use a small screwdriver or pick to get it off. Make sure you don’t go crazy and score the plug.
I should also mention, oil was changed at 600 or so miles and had a decent number of small chunks and quite a bit of metal flakes/glitter so I’d highly recommend doing it before 1000 miles. |
| FS (MD): Grimmspeed Intake, Perrin Inlet/CAI Filter, Green Air Filter | s203.22b | Engine, Exhaust, Bolt-Ons | 1 | 03-08-2021 12:25 PM |
| FS: 2 Oil Filters, 1 Cabin Air Filter, 1 Engine Air Filter, 2 Wipers | dk127itr | Mechanical Maintenance and Tools | 7 | 11-02-2020 11:13 PM |
| TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development | hirollaz | Engine, Exhaust, Bolt-Ons | 0 | 03-15-2017 02:46 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
