Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-15-2021, 02:49 PM   #1
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Oil Filter
Is the oil filter same as Forester? Does anyone have the part number?
Getting ready for the 1k breakin oil change
Stonehorsw is offline   Reply With Quote
Old 12-15-2021, 02:51 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Go pop your hood and get the number. It's printed right on the side.
Old 12-15-2021, 03:02 PM   #3
emce
emce's Avatar
Drives: 22 BRZ Limited
Here's the part number. I ordered it from that site but not trying to push them - I just couldn't find anything aftermarket at the time.
https://www.subarupartsdeal.com/part...5208aa170.html
emce is offline   Reply With Quote
Old 12-21-2021, 04:42 PM   #4
Stonehorsw
Stonehorsw's Avatar
The right parts number for the 22 BRZ is 15208AA170, and according to subaru’s service is same as wrx
Old 01-05-2022, 07:13 AM   #5
fastisfun
Drives: 2019 BMW M2C
Does the oil pan plug use a crush washer? I don't see one in the parts blow up.
fastisfun is offline   Reply With Quote
Old 01-05-2022, 07:50 AM   #6
emce
emce's Avatar
It does - same as previous gen: https://parts.subaru.com/p/Subaru__/...803916010.html
Old 01-05-2022, 07:54 AM   #7
dragoontwo
dragoontwo's Avatar
Yes. I see it in the engine section under oil pan, and also in the maintenance section right next to the drain plug.
Old 01-05-2022, 08:20 AM   #8
Stonehorsw
Stonehorsw's Avatar
The car came without, but on the manual is listed as optional. I installed for piece of mind, used from gen1.
Old 01-05-2022, 02:58 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
yours might be painted/glued on to your drain bolt or pan, so the washer is "missing"....
I had this issue with my 2013
https://www.ft86club.com/forums/showthread.php?t=54142
Old 01-05-2022, 03:10 PM   #10
dsc_pat
Drives: Too fast
Optional is the replacement of it, not its presence.
dsc_pat is offline   Reply With Quote
Old 01-05-2022, 03:53 PM   #11
Stonehorsw
Stonehorsw's Avatar
Probably it. I replaced both washer and plug on the first change. Makes sense
Old 01-08-2022, 07:31 AM   #12
fastisfun
I had to use a dental tool to remove my washer. Which was nearly invisible.
Old 01-10-2022, 12:04 AM   #13
LoneFashion
Drives: Arriving
I’ve never changed my oil myself but I just hit 1k miles in my brz. So, do I always change the oil filter when I change the oil and also, what oil do you recommend?
LoneFashion is offline   Reply With Quote
Old 01-10-2022, 01:48 AM   #14
Kona61
Kona61's Avatar
Drives: ‘22 CWP
The little washer gets painted over at the factory so it sticks to the drain plug. Use a small screwdriver or pick to get it off. Make sure you don’t go crazy and score the plug.
I should also mention, oil was changed at 600 or so miles and had a decent number of small chunks and quite a bit of metal flakes/glitter so I’d highly recommend doing it before 1000 miles.
Kona61 is offline   Reply With Quote
FS (MD): Grimmspeed Intake, Perrin Inlet/CAI Filter, Green Air Filter s203.22b Engine, Exhaust, Bolt-Ons 1 03-08-2021 12:25 PM
FS: 2 Oil Filters, 1 Cabin Air Filter, 1 Engine Air Filter, 2 Wipers dk127itr Mechanical Maintenance and Tools 7 11-02-2020 11:13 PM
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 02:46 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
