Old 12-12-2021, 06:47 PM   #1
jflogerzi
jflogerzi's Avatar
Falken RT660's Recommended Camber
I am planning my next set of tires for the up-coming season. Should get 1 more event out of my RE71's.
I think I have my choices down to 4 tires. All would be 245/40/17's
1) RT 660's
2) Kumo 730's (maybe 255's as they run narrow)
3) Hankook RS4's
4) nankang CR-1s
The Question is I only have 2.8-2.9 Camber in the front. Should I get some crash bolts and try for 3.5ish in the front?
2013 Series 10 FRS #553
Old 12-12-2021, 08:35 PM   #2
strat61caster
strat61caster's Avatar
Yes.
ineedyourdiddly
NoHaveMSG (12-13-2021)
Old 12-13-2021, 12:34 AM   #3
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Next season of what?
If it's autocross, of the four tires you listed, get the Nankang's. They are better then anything else you listed.
And, yes, more camber.
Breezio is offline   Reply With Quote
Old 12-13-2021, 10:09 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
If you're running 245s on 17x9s, crash bolts might not get you much if anything for camber, depending on wheel offset.
Old 12-13-2021, 10:40 AM   #5
jflogerzi
jflogerzi's Avatar
Apex Wheels. 35 offset. Coils are RCE's SS-1s maxed out at -2.8-2.9 of camber.
Season is for mostly HPDE's (little autocross) I do about 1-2 events per month skipping summer.
Old 12-13-2021, 11:19 AM   #6
steverife
Drives: 2016 Scion FRS
Yes.
steverife is offline   Reply With Quote
The Following User Says Thank You to steverife For This Useful Post:
strat61caster (12-13-2021)
Old 12-13-2021, 11:32 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you buy RT660's you are going to need to buy another set of tires anyway if you do more than 4 days a year.
Old 12-13-2021, 12:32 PM   #8
cueball89
Drives: 15 Impreza
For autox I have about -4.0 camber up front and -2.5 in the rear with the RCE SS-1's. Feels like it has more grip than the previous -3.25 and -2.2 camber alignment.
cueball89 is offline   Reply With Quote
The Following 2 Users Say Thank You to cueball89 For This Useful Post:
jflogerzi (12-14-2021), strat61caster (12-13-2021)
Old 12-13-2021, 01:18 PM   #9
RedReplicant
Drives: None
You're going to want to buy a pyrometer and learn to use it sooner than later.
RedReplicant is offline   Reply With Quote
The Following 3 Users Say Thank You to RedReplicant For This Useful Post:
CSG Mike (12-13-2021), downshiftxlr8 (12-13-2021), MacSpeed (12-13-2021)
Old 12-13-2021, 01:54 PM   #10
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
LOL kangs sucks. Sticker Kang to 110 run 660s on a 60s course we’re 1-1.5s slower.
Scrub kang (6 run) to scrub 660’s (24 run) kang was .5s down on a 34 second course.
MacSpeed is offline   Reply With Quote
Old 12-13-2021, 05:51 PM   #11
strat61caster
Concrete or asphalt?
ineedyourdiddly
Old 12-13-2021, 06:09 PM   #12
This is the answer.
Old 12-13-2021, 06:24 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
I found the CR-1s to be quite good at track events this past year. I ran them back-to-back vs. Yok A052s at Palmer (MA) and I'd say the CR-1s were maybe 0.5s slower. I would guess they should turn similar lap times to RT660 at the track, but that's based on performance of others on the 660s...
A052s should be quicker than any of the tires you mention. I did similar lap times to RS4s running my street Conti ExtremeContact Sports...
Icecreamtruk (12-13-2021)
Old 12-13-2021, 08:32 PM   #14
Icecreamtruk
Drives: Track preped NA FRS
I think the same as @ZDan regarding times, even tho I havent tried the nankangs myself I did the RT660 and A052 and they should be in the ballpark. Small caveat is that the yokos like a lot of camber to work well, Falken can still work with less but also prefer lots of camber. Maybe the CR1s work better on camber limited setups?
Re-71 vs Falken RT660 Autoenthusiastasm Tracking / Autocross / HPDE / Drifting 106 08-21-2021 02:29 PM
FS: Subaru BRZ Performance Package 17” wheels w/ 225/45/17 Falken Azenis RT660 brz_runner1129 Wheels and Tires 2 04-26-2021 08:42 PM
Recommended Camber for tracking Hags86 Tracking / Autocross / HPDE / Drifting 53 04-13-2020 10:26 AM
Thinking about lowering and camber adjustment, recommended shops in PDX? Llilith Northwest 4 09-08-2015 11:36 AM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
