Old 12-01-2021, 09:07 PM   #1
noid
noid's Avatar
Drives: 2014 Subaru BRZ
Harness Mounting question
Hey all,
So I purchased a 6 point sparco harness that uses clips for the lap belt. I am using a PCI Racing seat plate which has a mounting hole for the tunnel side lap belt, and I'm hoping to use the stock seatbelt's mounting point for the outer side of the lap belt.
Is there a solution for this without drilling, and then using eyelets and a backing plate? I already have a roll bar so the car has plenty of holes in it, but it looks as if the tunnel side has fuel lines running where the eyelet would need to go.
Should I just sell it and get a harness that doesn't use eyelets / clips?
Thanks - here's some pics that may help also.
noid is offline   Reply With Quote
Old 12-01-2021, 10:14 PM   #2
RedReplicant
Drives: None
Kinda confused what you're asking, but undo that bolt that you've got an arrow to and replace it with your eyelet.
For the sub belts you wrap them around the center section of the seat mount that has 4 bolts attached to it, assuming your harness doesn't have the clips sewn into it, otherwise you'd have to drill / backing plate for them.
Remember to cotter pin your harness clips too.
RedReplicant is offline   Reply With Quote
3D Printed Midbass Mounting Rings, OEM speaker harness pigtail projek_01 Audio/Visual, Electronics, Infotainment, NAV 3 08-07-2018 01:36 PM
aftermarket AGM battery mounting question CB390248 Engine, Exhaust, Transmission 0 01-23-2017 06:51 PM
Harness mounting in the rear with harness bar? HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 4 06-29-2016 06:45 AM
Harness Mounting Points Shakkazombie Scion FR-S / Toyota 86 GT86 General Forum 0 04-15-2015 01:36 AM
4 Point harness mounting locations for stock seat raytrix DIY (Do-It-Yourself) Guides 29 04-11-2014 10:36 PM
