Old 01-22-2014, 10:01 PM   #1
raytrix
Drives: Series 10 FR-S
4 Point harness mounting locations for stock seat
This looks kind of unsafe but I guess this is the quick and easy way that Japanese people do it. I would use this more for cosmetic purposes than actually use this setup on the road. Great for shows.
http://minkara.carview.co.jp/en/user...1214/note.aspx
raytrix is offline   Reply With Quote
Old 01-22-2014, 10:33 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Parked and/or show use is one thing, but don't use those while on the road as that is probably the most dangerous 4pt setup you can run
Old 01-22-2014, 10:40 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I'm sorry.... how is this a DIY?
No sane person would do something like this.
-alex
Old 01-22-2014, 11:14 PM   #4
1stGenBRZ86
1stGenBRZ86's Avatar
harnesses should NEVER be mounted like that.
1stGenBRZ86 is offline   Reply With Quote
Old 01-23-2014, 07:55 AM   #5
CoupedUpSubie
Drives: 2013 BRZ Limited
How is that unsafe? I got a bunch of parts for my rallyx car and a harness just like this was with it all. All that is needed is the points for the clips to go into. This is how I was instructed it was meant to be installed. Think about it, the bolts holding the shoulder straps are designed to hold you back in an accident already. Also the ones under the rails are in a spot just as strong.
Probably just an auto-x car although these seats don't really need it as they hold you better then any other seat I have sat in.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Old 01-23-2014, 09:12 AM   #6
mad_sb
Drives: 2013 Asphalt FR-S
Read the manufacturers install instructions, that will explain whats wrong. For starters the angle to the shoulder belts is far to steep. For another the lap belts should be mounted where the oem lap bet mounts.
Old 01-23-2014, 11:04 AM   #7
ScorpionOzzy
Drives: Scion FR-S
a shoulder harness should always be mounted directly behind you, never to the floor. When you crash, those harnesses are just going to compress your back, rather than just hold your body in the seat.
A simple harness bar would do the job just fine
ScorpionOzzy is offline   Reply With Quote
Old 01-23-2014, 11:11 AM   #8
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
That setup is unsafe. I talked to reps at Schroth and Takeda and both of them said the car's geometry is not fit to mount shoulder belts to the rear seatbelt points so they will not be making quick fit style harnesses for our cars. They strongly urge wrapping harnesses around rollcages are properly made harness bars.
The lap belt should pointed outward, and the outside lapbelt should really be mounted to where the factory seatbelt is located.
I second everyone who says its really important to pay attention to manufacturers recommendations regarding harness angles, etc.
F1point4 is offline   Reply With Quote
Old 01-23-2014, 11:33 AM   #9
DR 86
DR 86's Avatar
Dumbest thing I've read all year.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 01-23-2014, 11:42 AM   #10
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
This DIY should come with a eulogy.
Anthonytpt is offline   Reply With Quote
Old 01-23-2014, 11:53 AM   #11
CoupedUpSubie
I asked a question and made a few points of what I saw. I was looking for an informed response.
Old 01-23-2014, 12:16 PM   #12
mav1178
mav1178's Avatar
A simple Google search tells you:
https://www.google.com/search?q=race...w=1280&bih=939
The reason why they only provide you with the harness is, much like purchasing a set of wheels, there's no way for the manufacturer to know what type of vehicle it is going in to.
As others have covered (but not explained), harness mounting requires you to have the proper angles to prevent compression. You need to be secured, but also protected in case of a bad wreck. That's why harness bars always end up really close to your shoulder level.
Furthermore, while it is possible to use a racing seat with stock seat belts, using a harness with stock seats isn't ideal and can be dangerous. From the original picture, the harness passes between the posts for the headrest... now imagine your neck there. In an accident where the harness compresses, imagine your neck pinched in that tight location.
The shoulder harness should go OVER your shoulders, not choking your neck. Even if the harness was mounted properly, the location of the belts isn't idea for comfort or safety reasons.
But... the biggest red flag is, WHY THE HELL IS THERE A CAR SEAT IN THE FRONT SEAT?
Just because they're in Japan doesn't make them geniuses. Plenty of idiots over there too.
-alex
Old 01-23-2014, 12:31 PM   #13
CoupedUpSubie
-alex
Thank you.
I saw that part and did think of that scenario. The harness I have won't be going in my BRZ but my impreza which seems like it is a bit better setup for a harness. Now just to get a racing seat.
Old 01-23-2014, 02:27 PM   #14
DR 86
DR 86's Avatar
I have a question for you: what kind of harness do you have, and what is 1.8L of furry?
GoPro Mounting Locations Jericon Electronics | Audio | NAV | Infotainment 10 02-05-2014 12:24 PM
FS: Sparco Shoulder Pads and Tuner Style 4-point Harness Aznsky Interior Parts (Incl. Lighting) 7 07-21-2013 08:57 PM
Bucket seat store locations? CyberFormula Cosmetic Modification (Interior/Exterior/Lighting) 0 02-21-2013 09:16 PM
FS: Sparco 4-Point Racing Harness JPxM0Dz Canada Classifieds 2 01-12-2013 12:10 PM
Video/Go Pro Camera Mounting and locations diirk FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-02-2012 08:33 PM
