Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Audio/Visual, Electronics, Infotainment, NAV
Old 07-13-2018, 03:51 PM   #1
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
3D Printed Midbass Mounting Rings, OEM speaker harness pigtail
Hi,
I had these set aside for a local guy but he ended up flaking on me. Ill see if anyone on here is interested in them. They are designed to mount standard 6.5" (165mm) speakers to the OEM bolt holes. These are solid ABS so they are very rigid. I will also include the yellow EC2 connectors to make the wiring clean.
-Priced at 25USD plus shipping for the pair.
-I also have a extra pair of the wiring pig tails if you do not want to cut the factory speaker wiring harness for $5USD plus shipping
Attached are photos of a set I used in my car.
Thanks!
projek_01 is offline
Old 07-13-2018, 11:14 PM   #2
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
How far out do these put the speakers (from the door) and what is the cutout diameter? I have a set of Audiofrog GB60s (cutout diameter of 128mm) and would like to know if they would fit.
kmbkk is offline
Old 07-15-2018, 02:26 AM   #3
projek_01
projek_01's Avatar
@kmbkk
Wow, those are some darn nice drivers..... you are pretty serious about car audio. Sorry, I didn't see your post till now.
19mm total thickness from the door. I found that this is pretty much the furthest you can mount the drivers without trimming your door cards. I was able to put some ~3mm foam in front of the driver so the waves from the back of the driver cannot cancel out the front waves.
142mm cutout diameter. A little large for your driver but it should seal fine especially if you use foam or 3M tape on it.
If these aren't up to your standards, shoot me a private message. Thanks!
Old 08-07-2018, 01:36 PM   #4
projek_01
projek_01's Avatar
sold, please close!
Rear 3D Printed 6.5" Coax Speaker Adapters TurboBRZ Electronics | Audio | NAV | Infotainment 34 07-20-2021 11:39 PM
3D Printed Speaker Adapters Shankenstein Electronics | Audio | NAV | Infotainment 57 09-21-2017 07:55 PM
3D Printed 86 BRZ slimline number plate mounting bracket rickjames Cosmetic Modification (Interior/Exterior/Lighting) 3 03-01-2015 07:14 PM
Door Speaker Trim Rings Now Available zetaproducts.net Interior Parts (Incl. Lighting) 35 08-27-2013 09:52 AM
BRZ FOG LAMP Conversion Pigtail Harness Plug n Play JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 4 03-31-2013 05:07 PM
