Old 11-22-2021, 11:01 AM   #1
me2000000
EcuFlash gets stuck at 0% when reading flash
I am having an issue reading my ECU with ECU flash, I an using a tactrix openport 2.0 to attempt to read the flash on my 2013 FR-S. I have tried waiting anywhere between 15 seconds to a few minutes in between turning the key to the on position and starting the read. I have tried using an OBD 2 extension cable and tried replacing the usb cable between the tactrix and the laptop but it always seems to get stuck right after "entering bootloader".
I am looking for some troubleshooting advice on this. I have updated the 32bitbase.xml and the ZA1JA01C.xml files and made sure I have the correct and most up to date drivers for the tactrix. I have all unnecessary accessories powered off when attempting to read the flash.
I have attached a screenshot of the ecuflash log.
me2000000 is offline   Reply With Quote
Old 11-22-2021, 05:24 PM   #2
steve99
do you have anything else connected to can buss.
Had person with similar problem has a gerald jist Track box wired in it upset tactrix read.
once disconnected all ok
also make susre battery volts in car good and above 12v
and also try bending both rows of tactrix pins inward so it makes better connection with obd port or try a short obd extension cavle
Old 11-22-2021, 08:28 PM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I got flaky connections with an extension cable, but always good when directly connected.
Also any weird software on the PC?
Old 11-23-2021, 01:47 PM   #4
me2000000
I do have a Gerald Just Trac box. After disconnecting it ECUflash immediately was able to read. Thanks for the help guys. I am wondering now if I can rig up a switch to cut power to the Trac box when flashing.
The Following User Says Thank You to me2000000 For This Useful Post:
steve99 (11-24-2021)
Old 11-23-2021, 07:07 PM   #5
steve99
yes either drop power to trac bocpx or a double pole switch to diconbect it from CAN Buss may be better
Old 11-23-2021, 07:20 PM   #6
steve99
Jist talked to Geralld he said switch off all switches on track box to off then it should not send any data on CAN buss
Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging steve99 Software Tuning 1094 01-18-2026 04:44 AM
Tactrix EcuFlash. Scala Software Tuning 15 12-09-2021 09:36 PM
Idle MAP reading ~4psi but P3Gauge reading -20inHg FrickingReallySlow Software Tuning 6 10-08-2021 03:33 PM
OFT vs ECUFlash pseudo Software Tuning 31 05-01-2018 09:51 PM
Tactrix Ecuflash? enjoyminutemaid New England 1 08-13-2014 08:59 AM
