Old 09-29-2021, 02:41 PM   #1
FrickingReallySlow
Drives: 2015 FR-S
Idle MAP reading ~4psi but P3Gauge reading -20inHg
Looking for some help on this weird discrepancy between ECUTEK logging of MAP reading vs my P3Gauge.
I have a Edelbrock SC with Delicious tuning with D-Box smoothie. If you see my below log during idle the MAP sensor is reading ~4psi instead of vacuum. interesting enough my P3gauge reading ODB2 sees ~ -20inHg which is more in line.
I'm wondering why there's this discrepancy. Is there something in Delicious tuning that offsets the MAP during ECUTEK logging? which one is correct?
https://datazap.me/u/s0007/2k-6k-pulls?log=0&data=7-23
FrickingReallySlow is offline   Reply With Quote
Old 09-29-2021, 05:50 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Stock MAP sensor?
Old 09-29-2021, 06:30 PM   #3
FrickingReallySlow
Drives: 2015 FR-S
The edelbrock SC kit includes a 2 bar Bosch TMAP sensor. Even though both the P3Gauge and ECUTEK is reading from ODB2 I'm wondering if one is relative while the other is absolute. Spoke with P3 and they said even though the gauge is digital, vacuum is always displayed in -inHg while positive is in PSI
-20inHg is roughly -9.8psi. So if that's -9.8psi relative to atmospheric then 14.4-9.8 is roughly 4.9psi absolute. Not sure if this is correct assumption but welcome feedback here.
Old 09-29-2021, 08:05 PM   #4
steve99
Turn ignition full on , but engine off, map srnsor or guage should read 14 psi or 1 bar ie atmospheric if absolute or. 0 psi 0 bar if reliative
Also depends if your looking at reliative pressure or absolute
id say your reading reliative on one and absolute on the other
FrickingReallySlow (09-30-2021)
Old 09-30-2021, 03:27 AM   #5
tomm.brz
Drives: brz 2017 hksv2
yep looks ok
The Following User Says Thank You to tomm.brz For This Useful Post:
Old 10-02-2021, 06:06 PM   #6
Grady
Grady's Avatar
No discrepancy, engine computers calculate from absolute pressure. Relative pressure means nothing when calculating amount of fuel needed.
The Following User Says Thank You to Grady For This Useful Post:
FrickingReallySlow (10-08-2021)
Old 10-08-2021, 03:33 PM   #7
FrickingReallySlow
Drives: 2015 FR-S
Thx got the gauge to stay on with engine off and it reads 0 PSI.
Need Help Reading ECU Eddy98 Software Tuning 1 12-21-2020 03:59 AM
OFT not reading ECU Gray Fox Software Tuning 12 08-02-2017 06:44 PM
What is the expected vacuum reading at idle? qtwre Forced Induction 20 05-03-2017 10:27 PM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 01:26 PM
