Drives: 2018 BRZ tS
Tactrix EcuFlash.
Is anybody here CURRENTLY running EcuFlash and if so in order to tune for which modifications, which software version and with what success?
Thank you. |
Drives: Boosted Pandem V3
i used romraider to modify the tune, and ecutune to read and write the tune. i am running stage 2 UEL + added pop tune.
Drives: 2018 BRZ tS
Thank you. Please explain Stage 2 UEL.
stage 2 UEL can be downloaded from the OFT website with the right Ecu rom
#5 | |
Tactrix is a piece of hardware to connect to car ecu via obd port Ecuflash is software used by tacrix to read and write a file \tune from the ecu it can also edit tune files Romraider is tune editing software See link below for info on tune systems http://www.ft86club.com/forums/showthread.php?t=106068 Romraider editor tips http://www.ft86club.com/forums/showthread.php?t=79152 How to avoid bricking your ecu http://www.ft86club.com/forums/showthread.php?t=99171 Info specific to tactrix\ecuflash http://www.ft86club.com/forums/showthread.php?t=62332 Once you have read those most of your questions will be answered Yes lots of people use tactrix\ecuflash\romraider to flash and tune thier cars |
Drives: 2018 BRZ tS
Thank you.
It looks like I've got some reading to do. How about the OFT device and software updates? Other Forums for other brands report great frustration with the complete lack of support and the impossibility to communicate with the OFT people. |
#7 | |
Yeah they seem pretty busy But unlees you need custom tune or have some issue everyting you need for NA tunes is on thier dupport site http://support.openflashtablet.com/support/home Their is almost no support for tactrix\ecuflash |
Drives: 2018 BRZ tS
Thank you steve99, very good of you.
This tS will see mostly track days, very little DD and my expectation from the engine is mostly in the improvement of the mid-range. My own contribution to the project is a catted UEL header, 93 RON and a very elementary plug and play method of tuning. I could always run without the tune but I'd be foregoing the benefit of the high octane while I'd be taking risks with the AFRs. This is the reason of my interest in the OFT but I fear that, without support from OFT, going beyond simple icon selections will be well beyond my non-existent skills. Again, many thanks. |
#9 | |
I would suggest OFT + an e-tune from the like of @steve99 @Tor or @Waymo
2013 Series 10 FRS #553
#10 | ||
What @jflogerzi said is true, OFT is a super useful easy plug and play tuning tool that is well worth you purchasing. It's not worth getting header without a tune in my book, you're still going to get a CEL and really blowing your money away. You can easily use OFT to datalog and get the OFT guys to dial in your tune and you can details about etuning on their site, or pay @steve99 @Wayno or @Tor over paypal to do something similiar there the best guys on this forum for that stuff.
#11 | |
Drives: 2018 BRZ tS
Getting the OFT was my first thought but I didn't proceed once I realised that there is limited, if any, OE support. Now that I read in your posts that there is e-tune support available I will certainly go this route. Again, many thanks to both. |
#12 | |
#13 |
Rust bucket enthusiast
Why not get BRZ edit? That's what I use, it's decent for how cheap a personal license is. Uses Tactrix cable, essentially like any other open source tuning software. My tuner gave me a great dyno tune with UEL headers and cat delete, we're planning on using it when the car has the turbo installed.
#14 | |
The only real advantage of brzedit is it allows tuners to lock tunes and ecu. If i was going to spend money on a flash system other than tactrix\ecuflash or oft id go ecutek as it actually adds a lot of usefull features amd failsafes wehn going turbo, especially if you want electronic boost control |
| Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging | steve99 | Software Tuning | 1094 | 01-18-2026 04:44 AM |
| OFT vs ECUFlash | pseudo | Software Tuning | 31 | 05-01-2018 09:51 PM |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| Tactrix Ecuflash? | enjoyminutemaid | New England | 1 | 08-13-2014 08:59 AM |
| Any success with EcuFlash and F/I? | D-VO | Software Tuning | 4 | 06-26-2014 02:58 AM |
