Drives: 2013 Scion FRS, 2012 Tacoma
Turn signal issue/question
I just picked up my FRS last week and noticed an issue with the turn signals right off the bat. When I first hit the switch (right or left) the indicator and signals come on but don't flash. If I turn the wheel slightly they will start flashing. This happens if the wheel is straight, or even if the wheel is already turned. Would this be a clockspring issue? Maybe the flasher relay (seems less likely)?
The PO had every cheap LED imaginable installed on the car, so I replaced all of the bulbs with OE replacements and it didn't resolve the issue. I believe I had something similar happen with a 2004 Forester I owned a while back and there was a cup inside the steering column I had to replace. |
Senior Citizen Member
Welcome to the forum SportyTaco86! There are a couple of third-party turn signal relay replacements that can be programmed to flash in various patterns. They are fairly common and an easy plug-and-play mod. But sometimes prone to problems. Maybe verify if you have an original factory relay or an aftermarket and is it working correctly? I agree, not as likely, but fairly easy to check.
#3 | |
#4 | |
On another note, I've been dealing with a hyperflash issue on my Tacoma since installing aftermarket headlights (haven't had the time or motivation to add load equalizers), so maybe the LED relay will fit the Taco. |
#5 | |
ProCrastinationConsultant
https://www.diodedynamics.com/led-fl...ta-tacoma.html it's functionality is going to depend on if you have DTRL on your truck looks like there's some big threads on tacomaworld on this as well
#6 | |
| Turn signal cancelling/turn off issue | Koi | Issues | Warranty | Recalls / TSB | 5 | 10-18-2020 10:19 PM |
| TOMs & turn signal issue | Powered By Jay | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 01-14-2015 11:33 PM |
| OLM turn signal switchback issue | Scavanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 09-17-2014 11:42 AM |
| LED Turn Signal Issue | FR-S Matt | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 07-23-2013 12:47 PM |
| Turn signal issue | Asphaltfrs1 | Issues | Warranty | Recalls / TSB | 3 | 06-21-2013 06:06 PM |
