Old 03-26-2020, 12:03 AM   #1
Koi
Drives: 2013 Subaru BRZ Limited SWP
Turn signal cancelling/turn off issue
So I'm currently noticing a small issue with my turn signal switch. Everything is functioning properly except for when the turn signal cancels itself or turns off after a turn. When making a left turn, it cancels instantaneously when straightening the wheel. When making a right turn on the other hand, I noticed there's a delay when it cancels itself. When I'm straightening the wheel after a right turn, the steering wheel position would have to be back at the center for the turn signal to return to the neutral position.
Backstory:
Started noticing this issue when I removed quick release setup back to the OEM steering wheel. With that, the clock spring cover came off and so did cables inside. I tried my best winding it back and so far it hasn't been giving me issues. Was considering replacing down the road.
Was wondering if this issue can be related to the clock spring or turn signal switch?
Thanks!
Koi is offline   Reply With Quote
Old 03-26-2020, 01:18 AM   #2
humfrz
That would be my guess.
I'd suggest you leave it be, sounds like you have done messed it up enough.
humfrz
Old 03-27-2020, 11:12 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
That white pawl I'm moving with my finger normally catches on the clockspring, which you let come apart.
Things are probably not where they should be.
Old 09-16-2020, 11:47 PM   #4
Koi
Thank you for sharing! Since it's pretty much screwed, I was going to replace the clockspring unit down the road. Not really having issues at the moment... except it clicking off at awkward steering angles lol.
Also, how rigid is the white pawl? I just want to replace the clockspring and was hoping I wouldn't need to replace the blinker portion.
Old 09-17-2020, 03:34 AM   #5
RZNT4R
How rigid? Well you can see how much the tip of my finger is straining lol.
Old 10-18-2020, 10:19 PM   #6
Deemsim
Drives: 2013 Gt86
Hey Koi, did you end up replacing the clockspring? Im having a similar issue
Deemsim is offline   Reply With Quote
Turn Signal/Hazard Lights Issue Kutchak Issues | Warranty | Recalls / TSB 8 01-02-2022 09:25 PM
TOMs & turn signal issue Powered By Jay Cosmetic Modification (Interior/Exterior/Lighting) 19 01-14-2015 11:33 PM
OLM turn signal switchback issue Scavanger Scion FR-S / Toyota 86 GT86 General Forum 5 09-17-2014 11:42 AM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 12:47 PM
Turn signal issue Asphaltfrs1 Issues | Warranty | Recalls / TSB 3 06-21-2013 06:06 PM
