FT86Club Official Vendor
Drives: Miata, GT350, FR-S
Billet Camber Plates & Mounts @ 949 Racing
Our new shock mounts are in stock and ready to ship. Click link for more details. http://949racing.com/949-racing-shock-mount-86.aspx
Shocks we fit now: Xida (Tractive) MCS AST BC Racing (and derivatives) - Feal - Fortune Auto - Meister R - Stance The adapters on their way will add the following: TRD Tein (60 or 65mm springs) ST/ KW RSR RCE OEM Koni Bilstein JRZ
| The Following User Says Thank You to 949 Racing For This Useful Post: | Code Monkey (08-28-2021) |
Drives: Subaru BRZ
Is this -3.5 front camber at stock height?
Strut suspensions don't change camber much with height. Max camber with any strut will be when the LCA is level with the ground, ball joint at furthest distance from subframe. So full bump or full droop, the arc of the LCA puts the ball joint a few mm closer to subframe, which reduces camber by only a small fraction. Not like a wishbone or multi link where you can engineer in radical camber curves.
Technically, most strut cars lose camber as you lower them because the LCA's are tilted up, putting the ball joint closer to the subframe. One of several reasons we strongly recommend RCA (Roll Center Adjusters) on any 86 if you're lowering it. Blub uses the Whiteline kit and it's an integral part of its set up.
| The Following 2 Users Say Thank You to 949 Racing For This Useful Post: | Icecreamtruk (08-29-2021), wparsons (09-13-2021) |
Drives: 2013 FR-S, 2007 Acura TL 5AT
Impressive for about half the price of my RaceSeng camber plates - only feature missing being caster adjustment, but it's debatable how necessary that is.
2013 FR-S Raven, AutoX/Track/Daily Driver
Build: Angel's Dual Duty FR-S Build YouTube: Angel Christov |
#5 | |
We have not found a need for caster adjustment either. We have a design with caster adjustment but it added a lot of complexity, cost and wear points so we stuck with this simpler design.
| The Following 2 Users Say Thank You to 949 Racing For This Useful Post: | soundman98 (08-30-2021), Thefalls (08-31-2021) |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
I didn't see it listed, I would love to pick these up for my Bilstein B14s. Assuming it's compatible (specifically for the rear shock tops)
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
Correct. We do not have the right adapters for the Bilstein yet but are working on those. Should have them by December or so.
| The Following User Says Thank You to 949 Racing For This Useful Post: | Aztec (09-04-2021) |
#8 | |
Drives: Toyota 86
#9 | |
Most 86's set up for auto-x or HPDE are just running too little front camber. The other common issue we see are two piece China coilovers with lim ited bump travel paired with poorly designed camber plates that end up losing 1-2" of critical bump travel. So the front is on the bump stops in hard cornering, which generates understeer. So the owner puts a huge rear sway bar on trying to get rotation. The end result is a car that doesn't turn in well, has a twitchy rear end that requires lots of mid corner steering corrections and hates bumps. Sound familiar? Note how little steering angle, how well it takes the 10" tall kerbs, how few steering corrections needed. This was one of the many lap records Blub has. Camber plate design is just one piece of the puzzle.
| The Following 2 Users Say Thank You to 949 Racing For This Useful Post: | Calum (09-24-2021), marco_mc22 (09-04-2021) |
#10 |
More adapters being made. Should be here around December.
#11 | |
Drives: '13 FRS
#12 |
Yup. Always visit the product page for the latest information. If you are unsure, simply walk out to your car and take some measurements.
#13 | |
Drives: '13 FRS
I don’t have the MCS dampers yet to measure, they are on order. I can email Wyatt at MCS, but thought since I was purchasing the product from you, you’d be able to assist. The products are loaded into my cart on your page. The first drop down for options selection drop down box does not have MCS in the list although the second drop down box for shaft size does. Sent from my iPhone using Tapatalk |
#14 | |
I will update the site if that info is missing.
| What camber plates / top mounts for Ohlins? | Jakecox86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 02-28-2019 02:28 AM |
| FS: Moore Sport Front Camber Plates & Rear Top Mounts | Scracho | Canada Classifieds | 10 | 04-21-2018 03:59 PM |
| Raceseng | Billet Aluminum Caster Camber Plates | Raceseng | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 162 | 12-29-2014 10:32 AM |
| Color options Camber Plates, Stress Bar, & Shock Mounts | GC_Adam | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 03-26-2013 01:08 PM |
